[Solved] App::PropertyColor erroneous behavior
Evgeniy
Post by Evgeniy »
In short. Create some part... For example, the Cube in the workbench Part.
Open the View tab and try set the 'Shape Color' property, for example.
As a color, specify for example: red = 50, green = 100, blue = 200.
Press 'Ok', and then check which values are written to the property.
And you will see: red = 51, green = 99, blue = 198.
It was checked in Windows, perhaps this error is missing in other operating systems.
OS: Windows 10
Version: 0.21.0.31432 (Git)
I think this is due to the fact that the property App::PropertyColor uses a float color model like: (1.0, 1.0, 1.0, 1.0) and the color dialog returns values in the integer format like (255, 255, 255, 255) and after several conversions from integer to float and back, the color accuracy is lost.
user1234
Re: [Bug] App::PropertyColor erroneous behavior
Post by user1234 »
Evgeniy wrote: Sun Jan 15, 2023 10:17 pm It was checked in Windows, perhaps this error is missing in other operating systems.
I also noticed that recently, the question is if that is a QT issue.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.31599 (Git)
Hash: 12ed13ddbea126b40546d5b3d67fdeb6abeeece9
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.6.3
  * QuickMeasure 2022.10.28
  * CurvedShapes 1.0.4
  * Curves 0.6.5
Greetings
user1234
Evgeniy
Post by Evgeniy »
user1234 wrote: Sun Jan 15, 2023 10:26 pm I also noticed that recently, the question is if that is a QT issue.
from PySide2.QtGui import QColor
# Create color from integers
c = QColor(50,100,200,255)
# Convert integers to floats
cf = c.getRgbF()
# Create color from floats
nc = QColor()
nc.setRgbF(cf[0],cf[1],cf[2],cf[3])
# Convert floats to integers
print(nc.getRgb())
Doesn't look like... After several transformations, the result is the same... (50, 100, 200, 255)
It seems to me, in core is some code that uses its unreliable formulas instead of Qt methods for calculations.
user1234
Post by user1234 »
There was no QT update for a while. But as i remember, a few years ago, there was a similar issue.
Greetings
user1234
Evgeniy
Post by Evgeniy »
Roy_043
Post by Roy_043 »
The Decimals preference (Preferences_Editor#Units) is wrongly used to round the color values. Just play with that value and check the Python console after applying a color.
openBrain
Post by openBrain »
Merged a fix today.
Evgeniy
Re: [Solved] App::PropertyColor erroneous behavior
Post by Evgeniy »
Thanks. All work fine.
