[Solved] FreeCAD_weekly builds Windows missing
I can't find any FreeCAD_weekly builds for Windows
/BG
/BG
Re: FreeCAD_weekly builds Windows missing
@chennes @looo
i too can't see weekly build window, i try with chrome, edge and firefox but no file is shown
I can confirm on Linux with Firefox, no Windows weekly builds.
Probably something has happened, as I see two MacOs version on with python 3.10 and another with Python3.11 in the name.
But there is this on top:
That seems a windows build but not with the "usual name", it should be the "full installer" but as I'm not using Windows it is only a guess.
FreeCAD-0.21.0dev-31391-Installer.exe
434 MB 2022-12-22T03:22:18Z
Ciao Carlo,onekk wrote: ↑Mon Jan 16, 2023 12:45 pm I can confirm on Linux with Firefox, no Windows weekly builds.
That seems a windows build but not with the "usual name", it should be the "full installer" but as I'm not using Windows it is only a guess.Code: Select all
FreeCAD-0.21.0dev-31391-Installer.exe 434 MB 2022-12-22T03:22:18Z
yes the installer is a windows build but it's an old one (31391), the latest "visible" win-conda was 31513 dated January 8 (i've it on pc). After that, the win-conda disappears from weekly build
From what I kniw there were some problem on the building side, so some patience is needed.
Many things are happening behind the curtains, and it is hard to tell an unique place were to find information about what is in development at the moment.
Some refactoring of code is creating problems with different compilers used and some errors that as example are not present if you compile on Windows with his C compiler (VC compiler?) are present when you compile with Clang on Linux, or the inverse.
As example version 0.20.2 was compiled for Linux with some delay in respect to Windows due to some problem in the external library, compiler and such things.
- adrianinsaval
@looo it seems the bundles are being generated correctly but they are not found for upload anymore: https://github.com/FreeCAD/FreeCAD-Bund ... step:17:14
I think something changed in the github action that is used for upload, I asked about it: https://github.com/svenstaro/upload-rel ... 1385917165
