KGB_Knives wrote: ↑Thu Jan 12, 2023 7:21 am
bmsaus4ax wrote: ↑Wed Jan 11, 2023 8:41 pm
I am either doing something wrong or the file is still too large. I don't have an option to save the file for upload. I think I might be doing something wrong
.I deactivated all the parts and paths but still no joy.
Apologies I did not explain that very well .
The thing that contributes the most to the size of the final file is the
"CutMaterial" objects.
This is the result of running a "Simulation" for the operation,
you will see them at the bottom of the 'Tree' of the Combo view under the
Model tab (Labels and Attributes / Description ) as
CutMaterial, CutMaterial001, etc. There will be one for each time you have run simulation and clicked Ok.
Each of these objects can be quite large ( MB ' s )
If you see them delete them.
Deactivate the Operations with :
Select an operation
Select drop down menu
Path -> Toggle the Active State of the Operation or the equivalent icon.
This will reduce the file size some amount , not by a massive degree, but it helps.
The
"Save As" is only a time saver for your original file.
Whenever an Operation is deactivated the reactivation at a later time causes a recompute which in the case of a 3D Surface Operation can be a very long time. ( When you get all the faces you want working you may get a warning that FreeCAD is not responding, with the option of cancelling or waiting, you will need to wait as it is really still working)
If you make these changes and not Save your file but instead save your file with "Save As" with a different file name ; for example
"forum_handle_outside.FCStd", you will avoid the lost time of recomputing when you go back to your original file.
The file you attach to your post is the
Upload is not really what I should have said, but rather attachment as you have tried.
