printing on console from a script?
roegel
Post by roegel »
Hi
in my scripts, I want to print some stuff on the console or on the terminal where I launch freecad.
I have tried the following dummy example
import sys # first two lines to be able to launch with python alone
sys.path.insert(0,'/usr/lib/freecad/lib/')
from FreeCAD import Base
import Part
from math import *
a, b = 1, 2
print("a={0},b={1}".format(a, b))
but it prints nothing if I call freecad on the script. However, if I call python, then it prints
what I expect. Is there a way to get the printout if I run with the GUI?
Thanks,
Denis
shoogen
Re: printing on console from a script?
Post by shoogen »
Then please disable the redirection of internal python output to the report window using Edit -> Preferences -> General -> Output window -> redirect internal ....
mario52
Post by mario52 »
hi
since version 0.14 using "print" no longer works (Report view) !??
try with the function
a = 5
App.Console.PrintMessage("Value  : " + str(a) + "\n")
there also PrintWarning and PrintError
mario
For me it still works. You have to enable the option to redirect internal Python messages and errors to the report view.
roegel
Post by roegel »
Fo me too. shoogen's solution is fine.
Denis
mario52
Post by mario52 »
hi
Ok does it work thanks
mario
Tom1
Post by Tom1 »
Is there a way to keep all the variables after I run a python script, which means I can still load the python variables on console?
triplus
Post by triplus »
Tom1 wrote: Thu Aug 31, 2017 1:34 am Is there a way to keep all the variables after I run a python script, which means I can still load the python variables on console?
If you run the script directly in Python console then yes.
P.S. That is you need to define/assign the variable in Python console first.
