4th axis
4th axis
Hello everybody,
I already asked my questions in the geraman part of the forum. But I guess there will be a bigger community in the english vrsion, so maybe someone can help me.
for eht ereason that I switched my cnc machine to a 4th axis (6040), I would like to use the 4th axis to do some engravement with FreeCAD.
- is there a way to use greeCAD with a 4th axis?
- can I use X or Y axis for controlling 4th axis?
- are there any solutions or examples, as I didn't found anything expect one 9 second vid from sliptonics which doesen't answer any question
Thanx to everybody in advance for helping me.
Re: 4th axis
My help will probably be no real help. First I did not learn German despite having German speaking (bilingual) parents. I was a stupid child and now a now a stupid senior Also the cnc machine configuration will determine how things are defined in the FreeCAD operation.
and I hope a German speaker spots this post
Yes. In English it is the 'AxisMap Dressup'- is there a way to use greeCAD with a 4th axis?
X or Y from the g-code can be "wrapped" around a cylinder. The rotary axis turning that cylinder may be "A" or some other name.- can I use X or Y axis for controlling 4th axis?
If time allows I may post a YouTube video and link it here. No promises.- are there any solutions or examples,
Re: 4th axis
Sorry, no YouTube video so far. Only a FreeCAD file.
4th axis center-line is parallel to X axis.
Y axis wraps around the rotary.
FreeCAD reports some warning that seems safe to ignore.
btw this dress-up still scales wrong in imperial measurement.
Re: 4th axis
The video I remembered has an unexpected title.
Don't be fooled by the camera angle, the Y axis is not moving.
https://www.youtube.com/watch?v=sik5elnSge0
Re: 4th axis
So hello again.
First of all, I wann say sorry for non reaction, there where some healthy problems first (( Also, I completely refined the 3040 CNC. new ball-bearings, new CNC controller from Planet CNC, new ITX-Case, RemoteJog .... so now it's ready for work I hope
MANY THANKS for your help and Support.
I tried your Freecad-file. Looks nice and shows exactly what what I was searching nearly everywhere for. So, whith the right setting it's a charme. But, does the Radius input at axis map dressup need the final radius, or the Radius of the blank workpiece?
By the way, how sutiable is FreeCAD for doing some deepcarving like this:
https://www.youtube.com/watch?v=GaJJHgOH4cc
Do you have any experience an FreeCAD with this?
Thank you for your time for building up this example!!
Kind regards
Kind regards
Re: 4th axis
Yes this is possible in FreeCAD Path using 3D Surface operation.tomtom24 wrote: ↑Tue Feb 07, 2023 4:36 pm So hello again.
- headPath.png (150.46 KiB) Viewed 4412 times
- 20210406_110233.png (178.12 KiB) Viewed 4412 times
Re: 4th axis
I hope all is now well with your health.
Maybe there is a German translation of this wiki page ?
https://wiki.freecad.org/Path_Surface/en
Pay attention to the advice for "Low Memory".
the blank work piecedoes the Radius input at axis map dressup need the final radius, or the Radius of the blank workpiece?
Re: 4th axis
Heey, thx for your reply.bmsaus4ax wrote: ↑Tue Feb 07, 2023 10:48 pmYes this is possible in FreeCAD Path using 3D Surface operation.tomtom24 wrote: ↑Tue Feb 07, 2023 4:36 pm So hello again.
I have tryed to build up a simple example, maybe I missed the point, but, ... i do't get it working and I do not want to use another Prgramm as I like freecad for its technical background (which I might missunderstand sometifmes).
If you could please have a look at my attachament (3axis_test)? This would be very great as I still stuck
But I like your example. Looks very great.
At the end, and actually, I just want to mill out a honey spoon for my childs mother The shaft will be stabilized Wood (by vacuum), the pyramid itself won't get in touch with anything else than honey <3
Kind regards
- 3axis_test.FCStd
- (67.1 KiB) Downloaded 62 times
- honey.jpg (74.22 KiB) Viewed 4173 times
Re: 4th axis
Thank you Unfortunately, it never will be. But as long as I have Problems like this, everything is fine.
Yeah, I have thought in the same direction but I still have ~20GB constantly available and I guess, I will have just a "layer-8" problem ;)jbraun wrote: ↑Wed Feb 08, 2023 7:16 am Maybe there is a German translation of this wiki page ?
Hope it gets clearer as my experiance in freecad grows (which happend already)... step-by-step.
Kind regards
Re: 4th axis
The first thing to do is to rotate the model so that what you want to machine is under the Z-Axis.tomtom24 wrote: ↑Mon Feb 20, 2023 7:01 pm
The easy way to do this is with the Job Model after the Job is created.
:- Make the original model invisible
:- In the Job: Make the Job Model visible and rotate it to lie along the axis of the 4th-axis ( X = A or Y = B ) Use the Data -> Property -> Base -> Placement -> Angle and Axis to rotate 90 degrees
:- If the face to be machined is not pointing to Z-Axis,; In the Job -> Setup dialogue, Select the face and in the Set section, Select Z-Axis button.
---- the job should rotate to have the face up under the Z-Axis.
:- Select Refresh in the Stock section so the stock is again in line with the job. (do this anytime setting changes are made )
Then the Operations should create successfully, but 3D Pocket seems to not work as expected because it will not allow setting to cut full depth. A standard Pocket operation works on your model case.
Have attached a modified version of your file as examples
I do not know your exact FreeCAD version but I have used one of the last versions before the refactor which accepts your file.
The Honey Spoon looks like and interesting project that will require a few operations.
OS: Ubuntu 20.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
* fcgear 1.0.0
* Curves 0.4.4
* Lithophane
* CurvedShapes 1.0.3
- modified_3axis_test.FCStd
- (325.6 KiB) Downloaded 65 times
