[ ArchWall ] - Part.getSortedCluster, Part.sortEdges(), again
Re: [ ArchWall ] - Part.getSortedCluster, Part.__sortEdges__(), again
The py files use different EOL (end of line) characters. I have updated the ZIP file in my previous post.
How would I use the modified ArchWall.py in Freecad or replace the default one with it? Simply adding it as a macro and executing doesn't seem to do anything.Roy_043 wrote: ↑Tue Jan 03, 2023 10:34 am Attached is a ZIP with a modified ArchWall.py file and a FCStd test file. The original ArchWall.py is included in the Org folder. The modified code works on the 4 Xed rectangles (Sketch, Binder, Shape2DView and Link). But if you edit the Sketch and change the arc to normal geometry the results are less satisfactory. :mrgreen:
Backup: <installation_folder>/Mod/Arch/ArchWall.py and copy the new file in its place.
please tell me if this is off topic, but I found this might be useful for anybody using the realthunder branch. When trying to use the modified python script I got following error:
Checking Draft/draftgeoutils/faces.py the bind() function in the latest realthunder release does indeed not contain a per_segment argument. Using the faces.py from the latest official branch fixes the issue, archwalls.py now works as expected.
Huge thanks to Roy for the modified script :)
File "/Users/username/Applications/FreeCAD.app/Contents/Mod/Arch/ArchWall.py", line 1451, in getExtrusionData
face = DraftGeomUtils.bind(w1, w2, per_segment=True)
<class 'TypeError'>: bind() got an unexpected keyword argument 'per_segment'
07:20:01 9.7e-08 <App> ArchWall.py(341)|Document.cpp(4327): Failed to recompute type1_schablone#Wall: bind() got an unexpected keyword argument 'per_segment'
07:20:01 Recompute failed! Please check report view.
- Screenshot 2023-01-06 at 07.41.03.png (146.9 KiB) Viewed 955 times
although interestingly on this example the original archwall.py produces a better result.
original: Roy's version:
Thanks @eigenwertnotfound for testing, can share the model file ?
Hi paullee, archwall_gridtest is the sketch I originally broke it with. I tried to provide a minimal example where it breaks and now the crossed box which worked for me originally doesn't work either (although it breaks in a different way than the original python script). Very confused right now...
- archwall_gridtest1.FCStd
- (35.59 KiB) Downloaded 23 times
- archwall_gridtest.FCStd
- (29.77 KiB) Downloaded 22 times
Interesting grid test. Need to avoid multiple edges with ends coincidence - though it may be natural to layout like this.
May have an idea how to tackle this.
Test result on my FC 0.21.0.31391, AppImage on Fedora 36
OS: Fedora Linux 36 (Workstation Edition) (GNOME/gnome)
Version: 0.21.0.31391 (Git)
Hash: 0ab2608a429f3a5ee9a63da9b66d13557655d7e4
* dodo 1.0.0
* DynamicData 2.46.0
* ArchTextures
* BOLTSFC.backup1666323893.5041647
* BOLTSFC
* FreeCAD-BlenderBIM.backup1666328110.015535
* FreeCAD-BlenderBIM.backup1666737837.420096
* FreeCAD-BlenderBIM 2022.10.20
* BIM.backup1670731522.690569
* BIM 2021.12.0
* 3rd link to Paul
* 3rd link to SketchArchPlus
Re: [ ArchWall ] - Part.getSortedCluster, Part.sortEdges(), again
OK, tests to see different in behaviour in sorting edges in Sketch by :
Test 1 : Used Part.getSortedCluster()
- Part.getSortedCluster()
- Part.sortEdges() (Not Part.__sortEdges__(), which return only 1st edge)
- Steps - Run below codes after file opened
- Result - 2 shapes created (1st 5 edges with the diagonal one ('self-intersecting'), 2nd with the opposite diagonal edge)
( 2nd screencapture )
- Steps - Codes remark out line 14, un-remark line 15; run revised codes after file opened
- Result - 3 shapes created ( 1st 4 edges, 2nd with the diagonal one, 3rd with the opposite diagonal edge)
( 3rd screencapture )
obj = FreeCAD.ActiveDocument.getObject('Sketch')
skGeom = obj.GeometryFacadeList
skGeomEdges = []
skPlacement = obj.Placement # Get Sketch's placement to restore later
basewires = []
for i in skGeom:
if not i.Construction:
# support Line, Arc, Circle for Sketch as Base at the moment
if isinstance(i.Geometry, (Part.LineSegment, Part.Circle, Part.ArcOfCircle)):
skGeomEdgesI = i.Geometry.toShape()
skGeomEdges.append(skGeomEdgesI)
for cluster in Part.getSortedClusters(skGeomEdges):
#for cluster in Part.sortEdges(skGeomEdges):
clusterTransformed = []
for edge in cluster:
edge.Placement = edge.Placement.multiply(skPlacement) ## TODO add attribute to skip Transform...
clusterTransformed.append(edge)
# Only use cluster of edges rather than turning into wire
basewires.append(clusterTransformed)
c = [App.Placement(App.Vector(6000.0,2000.0,0.0),App.Rotation(App.Vector(0.0,0.0,1.0),0.0)), App.Placement(App.Vector(6000.0,-2000.0,0.0),App.Rotation(App.Vector(0.0,0.0,1.0),0.0)) , App.Placement(App.Vector(12000.0,0000.0,0.0),App.Rotation(App.Vector(0.0,0.0,1.0),0.0)) ]
print(basewires)
len(basewires)
for i in range(len(basewires)):
w=Part.Wire(basewires[i])
w.Placement = c[i]
Part.show(w)
