CFDOF meshing problem--installation?
Moderator: oliveroxtoby
pdschroder
Post by pdschroder »
I had trouble installing CFDOF and its dependencies, but I think they are mostly there now. I can write the mesh case, and it looks like the mesher runs, but it exits with:
16:44:48 CharacteristicLengthMax: 5.0
16:44:48 Exporting mesh refinement data ...
16:44:48 Matching boundary patches
16:44:48 Matching mesh refinement regions
16:44:48 Exporting the part surfaces ...
16:44:49 Triangulating part Pad001, patch patch_1_0
16:44:49 Triangulating part Pad001, patch patch_2_0
16:44:49 Triangulating part Pad001, patch patch_3_0
16:44:49 Populating mesh dictionaries in folder C:\Users\Paul\AppData\Roaming\FreeCAD\Mod\CfdOF\meshCase
16:44:49 Successfully wrote meshCase to folder C:\Users\Paul\AppData\Roaming\FreeCAD\Mod\CfdOF\meshCase
16:44:49 Wrote mesh case to C:\Users\Paul\AppData\Roaming\FreeCAD\Mod\CfdOF\meshCase
16:45:06 Executing: ./Allmesh in C:\Users\Paul\AppData\Roaming\FreeCAD\Mod\CfdOF\meshCase
16:45:07 Sourcing OpenFOAM environment...
16:45:07 openfoam: windows support (mingw64) is runtime only
16:45:26 C:/Users/Paul/AppData/Roaming/ESI-OpenCFD/OpenFOAM/v2206/msys64/home/ofuser/OpenFOAM/OpenFOAM-v2206/platforms/win64MingwDPInt32Opt/bin/surfaceFeatureEdges.exe: error while loading shared libraries: libmeshLibrary.dll: cannot open shared object file: No such file or directory
16:45:45
Did I not get OpenFOAM installed correctly? Can someone tell me how to fix it?
pdschroder
Re: CFDOF meshing problem--installation?
the last error message says it's looking for surfaceFeatureEdges.exe, and I see that file in the path it gives. I can't figure out what I'm doing wrong.
I moved this from the general install forum. The CfdOF experts are rather here.
oliveroxtoby
Post by oliveroxtoby »
pdschroder wrote: Mon Dec 26, 2022 11:54 pm I had trouble installing CFDOF and its dependencies, but I think they are mostly there now. I can write the mesh case, and it looks like the mesher runs, but it exits with:
16:45:45
Most likely cfMesh hasn't installed correctly. Please see the link below for some hints.
Please provide all the information requested in this post before reporting problems with CfdOF.
