Arch material creates material even if you cancel the operation and the material cannot be deleted
hko
Post by hko »
- Open a new document and select Arch workbench
- Click Material tools -> Material
- Click Cancel
- Observe that you now have "Materials" group in the tree and there is "Material" inside it
- If you do that again, you get Material001 etc.
- Try to delete Material by selecting Delete from the context menu of Material
- Observe that Material is not deleted
- Edit material and choose a preset and click Ok
- Now try to delete Material
- Observe that Material is deleted
OS: Ubuntu 20.04.5 LTS (KDE/plasma)
Version: recent master, see hash
Build type: Debug
Hash: 8b85903dffe3a9a02dd3738ea8931f3e52e59463
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
  * 3DfindIT 1.2.0
  * Render 2022.3.0
  * BIM 2021.12.0
  * Reinforcement
  * Manipulator 1.4.9
  * Assembly4.backup1662941442.2770898
  * parts_library
  * Assembly4 0.12.5
  * fasteners 0.4.50
  * Silk 1.0.0
  * dodo 1.0.0
  * Curves 0.6.5
Roy_043
Re: Arch material creates material even if you cancel the operation and the material cannot be deleted
Post by Roy_043 »
Confirmed. I have a PR prepared related to the edit modes of Arch objects. This PR will also fix the delete problem you mention (FreeCADGui.ActiveDocument.resetEdit() is currently not called when Cancel is pressed).
There is some confusion about how the tool should work. The tooltip "Creates or edits the material definition of a selected object" is not accurate, a new material is always created and you do not have to select an object. Maybe "Creates a new material definition and opens it for editing" would be better. Cancelling the edit operation would still leave you with a new material.
Version: 0.21.0.31432 (Git)
Hash: 63a2855751d638bf27ed969dc60654bda2b54baf
