thomas-neemann
Posts: 11921 Joined: Wed Jan 22, 2020 6:03 pm
Post
by thomas-neemann » Sun Dec 18, 2022 6:55 pm
is that a solution?
Agonfree
Posts: 8 Joined: Sat Dec 17, 2022 1:41 am
Post
by Agonfree » Sun Dec 18, 2022 7:06 pm
I did it but still have the same problem
Agonfree
Post
by Agonfree » Sun Dec 18, 2022 7:19 pm
At first picture are my settings to maximize the precision. if you can see on the second picture my snap point is still outside of my circle.
thomas-neemann
Post
by thomas-neemann » Sun Dec 18, 2022 7:26 pm
Agonfree wrote: ↑ Sun Dec 18, 2022 7:19 pm
That shouldn't be a problem, it's just an inaccuracy in the display
Agonfree
Post
by Agonfree » Sun Dec 18, 2022 7:56 pm
Thank you so much i can understand why this is outside of the circle. i have measured the the lines and they give the same dimension.
I have another question how can I extrude this shape fully extrude not just lines.
fill.FCStd
(17.61 KiB) Downloaded 27 times
Roy_043
Posts: 8552 Joined: Thu Dec 27, 2018 12:28 pm
Post
by Roy_043 » Sun Dec 18, 2022 8:09 pm
The largest semi-circle intersects the two lines, therefore the contour cannot be extruded as a solid.
