Let me know if there's any other info I should provide. Any help is greatly appreciated.
00:51:38 1.381229 <asm3.main> init_gui.py(14): no solver backend found
00:51:45 FreeCAD 0.20, Libs: 2022.1213R14555 (Git shallow)
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
Adding snap-specific PYTHONPATH to sys.path: /home/ryan/snap/freecad-realthunder/common/.local/lib/python3.8/site-packages:/snap/freecad-realthunder/97/lib/python3.8/site-packages:/snap/freecad-realthunder/97/usr/lib/python3/dist-packages
00:51:45 >>> >>> >>> >>> ... ... ... ... ... ...
ERROR: Exception:
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/base_command.py", line 160, in exc_logging_wrapper
status = run_func(*args)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 247, in wrapper
return func(self, options, args)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 326, in run
session = self.get_default_session(options)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 98, in get_default_session
self._session = self.enter_context(self._build_session(options))
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 125, in _build_session
session = PipSession(
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/network/session.py", line 343, in __init__
self.headers["User-Agent"] = user_agent()
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/network/session.py", line 140, in user_agent
linux_distribution = distro.name(), distro.version(), distro.codename()
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_vendor/distro/distro.py", line 297, in name
return _distro.name(pretty)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_vendor/distro/distro.py", line 842, in name
self.os_release_attr("name")
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_vendor/distro/distro.py", line 1032, in os_release_attr
return self._os_release_info.get(attribute, "")
File "/snap/freecad-realthunder/97/usr/lib/python3.8/functools.py", line 967, in __get__
val = self.func(instance)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_vendor/distro/distro.py", line 1070, in _os_release_info
with open(self.os_release_file, encoding="utf-8") as release_file:
PermissionError: [Errno 13] Permission denied: '/etc/os-release'
File "<stdin>", line 6, in <module>
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/base_command.py", line 216, in _main
self.handle_pip_version_check(options)
File "/snap/freecad-realthunder/97/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 179, in handle_pip_version_check
session = self._build_session(
OS Name: Pop!_OS 22.04 LTS
OS Type: 64-bit
GNOME Version: 42.5
