[Issue #8044] Undo doesn't work on Draft Move function
Re: Undo doesn't work on Draft Move function
Issue is reported for Version: 0.21.31109 (Git)
Issue isn't reproduced on Version: 0.21.0.31312 (Git)
@acp693 can you test on the latest dev version ?
Just downloaded and tested. Exactly the same behaviour on the latest dev version
Version: 0.21.0.31340 (Git)
Hash: 856af2a12287a2d7c0d5ab23646be43af26b14b1
* CurvedShapes 1.0.4
* Curves 0.5.3
* ExtremeProLight 1.4.3
* FeedsAndSpeeds 0.5.0
* Marz 0.0.26-alpha
* Silk 1.0.0
Thanks.
Moved thread to Draft subforum.
I have spent some time trying to analyze this bug. It also occurs if you change the Placement of a Draft object in the Properties editor. The problem does not occur in V0.18. It seems some regression, that only affects Windows users apparently, was introduced in V0.19.
Version: 0.21.0.31432 (Git)
Hash: 63a2855751d638bf27ed969dc60654bda2b54baf
OS: Windows 8.1
Word size of FreeCAD: 32-bit
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
@Roy_043 you have solved many of my reported bugs/questions.Roy_043 wrote: ↑Sun Jan 01, 2023 10:03 am I have spent some time trying to analyze this bug. It also occurs if you change the Placement of a Draft object in the Properties editor. The problem does not occur in V0.18. It seems some regression, that only affects Windows users apparently, was introduced in V0.19
Many thanks for your confirmation and valuable input to the forum.
Hopefully @acp693's bug report will be solved and merged ASAP
Cheers
Re: [Issue #8044] Undo doesn't work on Draft Move function
I have added test files on GitHub:
https://github.com/FreeCAD/FreeCAD/issu ... 1374427577
Tried the new files, works as it should as far as I can tell. Thank you very much @Roy_043
Thanks for testing. Still doing some testing myself.
Many thanks for your contribution.
I have been testing for some time, sorry for the slow response.
It does not works all times (rotate or move).
Use the attached test file to reproduce the fault (you may need to repeat both rotate/move to different positions).
Some time works for one fails for other.The attached images works for rotate and fails for move
Version: 0.21.0.31513 (Git)
Hash: b2ab8edba4bfd71681e639f8c3f1105066bed4c7
* Behave-Dark-Colors 0.1.1
* BIM 2021.12.0
* Defeaturing 1.2.0
* Dracula 0.0.2
* ExtremeProDark 2.6.4
* fasteners 0.4.24
* SketchArch
- Test File-R1.FCStd
- (13.72 KiB) Downloaded 34 times
- Image 1.jpg (85.21 KiB) Viewed 1079 times
Thanks for testing. AFAICT the attached file (gui_base_original.py) fixes this problem.
Target folder for the file:
<installation_folder>/Mod/Draft/draftguitools/
- gui_base_original.py
- (11.59 KiB) Downloaded 33 times
