acp693
Posts: 127 Joined: Wed Dec 15, 2021 7:41 pm
Post
by acp693 » Tue Dec 13, 2022 3:20 pm
Hi, If I have a line (or lines) created in the Draft workbench and I use the move function, and then press Undo (ctrl z), the line doesn't move back to it's original position. As far as I can see, there's no way of putting it back exactly where it was, or am I missing something? Other objects respond to the undo button after using Draft Move such as a primitive solid created in Part WB.
Version: 0.21.31109 (Git)
Hash: c23ee7ad88433a0f00e84afae0a62fe738be0c09
* CurvedShapes 1.0.4
* Curves 0.5.3
* FeedsAndSpeeds 0.5.0
* Marz 0.0.26-alpha
* Silk 1.0.0
drmacro
Posts: 8979 Joined: Sun Mar 02, 2014 4:35 pm
Post
by drmacro » Tue Dec 13, 2022 3:34 pm
Seems to work here...
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.0.31312 (Git)
Hash: 309718bde8a92481c768ca0116401e18759a32b8
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
* parts_library
* kicadStepUpMod 10.16.5
* Manipulator 1.4.9
* PrefExtras
* QuickMeasure 2022.10.28
* MyDefaults 2022.9.15
* ZolkoBase 0.0.1
* lattice2 1.0.0
acp693
Post
by acp693 » Tue Dec 13, 2022 3:43 pm
Thanks Are you pressing ctrl z to undo?
I've made the following discovery: I press ctrl Z after a move, nothing happens. If I then press ctrl y, the line moves back to it's original position
drmacro
Post
by drmacro » Tue Dec 13, 2022 4:00 pm
I pressed ctrl-z.
Not sure it matters, but, I'm using CAD navigation style.
Someone with windows might confirm what you are seeing.
acp693
Post
by acp693 » Tue Dec 13, 2022 4:11 pm
Thanks.
Just found out 'Rotate' has the same problem
Can someone on Windows confirm?
Palmtree
Posts: 104 Joined: Wed Apr 08, 2020 5:06 am
Post
by Palmtree » Wed Dec 14, 2022 12:03 am
acp693 wrote: ↑ Tue Dec 13, 2022 3:20 pm
line
doesn't move back to it's original position ==>
CONFIRMED
Just found out '
Rotate ' has the same problem ==>
CONFIRMED
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
* Behave-Dark-Colors 0.1.1
* BIM 2021.12.0
* Dracula 0.0.2
* ExtremeProDark 2.6.4
* fasteners 0.4.24
* SketchArch
Palmtree
Post
by Palmtree » Thu Dec 15, 2022 1:01 am
Many thanks for repotting and creating a bug report.
Please note that I have reported similar problem earlier (refer to the attached post).
* BIM 2021.12.0
* Dracula 0.0.2
* fasteners 0.4.24
* SketchArch
acp693
Post
by acp693 » Thu Dec 15, 2022 9:13 am
@Palmtree That's a similar problem I have, I'm moving an image togther with some draft construction lines, if I make a mistake moving, and press return, the image returns to the original position, but the draft lines don't, completely ruining the respective positions they had. If I then press redo to move the image back to the moved position it does that, but the lines also move back to the original position.
Bernard19
Posts: 889 Joined: Sun Feb 20, 2022 7:16 pm
Post
by Bernard19 » Thu Dec 15, 2022 6:07 pm
I confirm on Windows - I have a similar problem.
Locale: French/France (fr_FR)
