[ BUG #7872 ] pocket up to face/up to first create traces and multiple faces
Piero69
Post by Piero69 »
as discussed with @chrisb in https://forum.freecadweb.org/viewtopic.php?f=8&t=73760 i would like to open here this bug about the missing refine (and auto-refine when set in preference as i have) in pocket feature with option up to face/up to first.
it's true that eventual following features refines the model but if for some reasons the cut is compulsory the last feature in the model we get an incorrect outcome with traces and multiple faces. The error spreads also to exported step for example
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.31058 (Git)
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Italian/Italy (it_IT)
  * 3DfindIT 1.2.0
  * A2plus 0.4.54b
  * Assembly3 0.11.4
  * Assembly4 0.11.8
  * Behave-Dark-Colors 0.1.1
  * BOLTSFC
  * CurvedShapes 1.0.4
  * Curves 0.6.1
  * dxf_library
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners
  * FCGear
  * freecad.gears 1.0.0
  * ImportNURBS
  * InventorLoader 1.3.0
  * InventorLoader.backup1663313199.3655012
  * invgears 0.1.2
  * lattice2
  * nurbs
  * Render 2022.1.0
  * sheetmetal 0.2.59
  * sheetmetal.backup1663313192.0420823
  * Silk -1321532872.0.0
  * symbols_library
Bug Up to face-up to first.FCStd
(19.59 KiB) Downloaded 45 times
Bug Up to face-up to first.jpg (179.49 KiB) Viewed 1015 times
Shalmeneser
Re: [ BUG ] pocket up to face/up to first create traces and multiple faces
Post by Shalmeneser »
Same problem in 0.20.28611. Is it a new problem or from ever ?
To wake the refine up, it's possible at the end to Pocket an 'outside' face with reversed=on for a null-feature.
(btw, can you clip your pictures ?)
I don't see the point of creating a new forum topic, instead please create an issue on the GitHub issue tracker
Re: [ BUG #7872 ] pocket up to face/up to first create traces and multiple faces
issue #7872 was created and also includes an example file
