[solved] manual installation of hisa/cfmesh fails
Moderator: oliveroxtoby
thschrader
Post by thschrader »
just updated the cfdof workbench. When trying to update cfmesh/hisa with the
"Choose existing file..." option, I get this error:
16:09:06  Traceback (most recent call last):
16:09:06    File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\CfdPreferencePage.py", line 339, in pickCfMeshFile
16:09:06      f, filter = QtGui.QFileDialog().getOpenFileName(title='Choose cfMesh archive', filter="*.zip")
16:09:06  AttributeError: PySide2.QtWidgets.QFileDialog.getOpenFileName(): unsupported keyword 'title'
Freecad:
Version: 0.21.31058 (Git)
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
  * BIM 2021.12.0
  * CfdOF 1.20.3
  * Curves 0.5.8
  * Defeaturing 1.2.0
  * dodo
  * fasteners 0.4.4
  * Manipulator 1.4.9
  * Plot 2022.4.17
  * Reinforcement
  * WorkFeature
markrmau
Re: manual installation of hisa/cfmesh fails
Post by markrmau »
Does it work if line 339 of CfdPreferencePage.py is changed to:
f, filter = QtGui.QFileDialog().getOpenFileName(None, 'Choose cfMesh archive', '', "*.zip")
Same issue on lines 307, 318, 360 but with the different titles & filters
The file is located here:
%appdata%\FreeCAD\Mod\CfdOF\CfdOF
My FreeCad version doesn't require this file change, so the issue may be due to a Qt library change:
Python 3.8.10
Qt for Python (PySide) 5.15.0
Qt 5.15.2
oliveroxtoby
Post by oliveroxtoby »
thschrader wrote: Wed Nov 23, 2022 3:15 pm Hi,
Hopefully fixed now...
thschrader
Works, installation in progress... Thanks.
thschrader
oliveroxtoby wrote: Wed Nov 23, 2022 6:18 pm
FYI:
cfmesh and hisa installation runs with no problems, mesher and solver now running.
