help with modeling a telescope mount
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
jrg
Post by jrg »
I am working to customize my amateur telescope mount and will ultimately be machining some custom pieces that attach to the mount. In order to design this piece I need to create a basic model of the telescope mount and the telescope. I have all the detailed measurements of the mount and telescope and want to create an assembly that can move and I look for collisions between the telescope and the mount and then later the custom optical pieces I add in. So I'm looking to get someone to create the 3D model in FreeCAD from the measurements I have.
I'm new to FreeCAD and have been learning but think this is something that someone with experience can do relatively quickly and also best select the right assembly add-on to use. I think it is simplest to pay by the hour for creating this design. If you are interested please let me know your rate and availability. Thanks!
Re: help with modeling a telescope mount
I'm interested, we could talk using this forum PM.
mario52
Post by mario52 »
keithsloan52
Post by keithsloan52 »
jrg wrote: Mon Nov 21, 2022 10:57 am I am working to customize my amateur telescope mount and will ultimately be machining some custom pieces that attach to the mount. In order to design this piece I need to create a basic model of the telescope mount and the telescope. I have all the detailed measurements of the mount and telescope and want to create an assembly that can move and I look for collisions between the telescope and the mount and then later the custom optical pieces I add in. So I'm looking to get someone to create the 3D model in FreeCAD from the measurements I have.
You might want to to checkout
Image 11-02-2023 at 21.30.jpg (75.47 KiB) Viewed 3723 times
see viewtopic.php?style=10&t=66567
and https://github.com/ljplessis/Nikra-DAP
