A small test.
minor:
- Like someone mentioned, at starting the warning
show up
- The new preferences have good texts per element, but all in context combined a little bit hard to understand.
- Somehow sometimes the quicktips not the overly icons do not work, can not fine a systematic atm.
general:
- UI things on the 3D view are not respected, like the FPS counter, coordinate system in the corner and the navigation cube.
- When 2 panels are combined in one widget, the whole size is not adaptable, but its separation. So it can not maximized. Also the horizontal size can not be adjusted per element while working. This is very important, since some panels are much narrower then others and some text boxes are cut (you can do it with a workaround, toggle it to normal, resize, toggle it to transparent).
- The colors/transparency of the of the background of the widgets are not optimal atm.
- The good thing is you can easily use the default usage every time
conclusion: good start, but needs refinement
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.31354 (Git)
Branch: OverlayWidgets
Hash: a2f235cd2a0a4f4c56c8011ea736376259a5160d
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.6.3
* QuickMeasure 2022.10.28
left master, right OverlayWidgets
Greetings
user1234
