well, see my previous point:paddle wrote: ↑Wed Nov 09, 2022 8:55 am @pathfinder I think this is why transparency is nice, because even with the tree and task separated, you still have a lot of 3D view. I don't think there are so many task boxes open all the time, so it wouldn't take so much space. Besides taskboxes are mostly meant to appear when you actually need them.
TL;DR: In my experience, transparency looks nice but is distracting and tiring when you work for hours and hours.pathfinder wrote: ↑Tue Nov 08, 2022 10:50 pm […]
It's hard to put into words why exactly that is, but I think it has to do with compartmentalization, as in what you expect to be where and what it does to your attention when things change constantly. With transparency, everything is potentially dynamic. And while rationally, it shouldn't make much of a difference, because things don't change positions, when actually working with it, it kind of does, probably because the backgrounds of treeview and potentially other functions are essentially dynamic and that kind of triggers some peripheral view instinct that tells you something unexpected is going on, if that makes sense? The closest thing I can think of in regular FC is the report view popping off with yet another error message that you decided to ignore ages ago because it's actually not a big deal or a false-positive anyway, but it still makes your eyes twitch in that direction for a second.
As with task boxes, really, most of the time I do some task.
I've thought about it some more and came to the conclusion that while consistency is nice, maybe there should be exceptions. For example, in Sketcher, the tree view is usually not as useful, because for most things to do there, you'll have to exit the sketch anyway. So having the task window overlaid doesn't take much away.
For other operations on the other hand, I tend to switch back and forth; mainly to toggle visibility on objects, to go into the property view (which the task view also covers) and so on. So there's an argument to be made that maybe, there should be two different options that are based on how likely it is that the treeview and/or property view are needed during a given task. It's probably not a popular position, but I put it out here anyway.
