[BUG] Crashes after trying to add reference dimension
luwol03
Post by luwol03 »
I tried to create a reference dimension in this moddle, like seen in the video. However the first time I got no reference dimension and the second time it completely crashed.
Steps to reproduce: see video (https://drive.google.com/file/d/1OJOgcX ... sp=sharing)
version:
OS: macOS 10.16
Version: 0.20.1.29410 (Git)
Locale: C/Default (C)
  * A2plus 0.4.56a
  * BIM 2021.12.0
  * kicadStepUpMod 10.13.0
  * Assembly4 0.12.3
test.FCStd
(223.02 KiB) Downloaded 44 times
Re: [BUG] Crashes after trying to add reference dimension
No problem here. Please retry with curent 0.21.
The video has a horrible resolution, takes time to watch, and not everyone has unlimited bandwidth. For future posts please minimize the file (is it really necessary to have all these things in the tree?) and add a step by step description how to reproduce. This is what I did:
- Edit "Sketch"
- Switch to driven constraints (blue dimensions)
- select vertical distance constraint
- select the origin
- select a point at the right lower corner, I used Vertex3
-> no crash, the driven dimension is added.
OS: macOS 10.16
Version: 0.21.30430 (Git)
Hash: 9e1ed4a68ad43309c2b38f7f5efbb1feac4323cb
  * FC_SU
  * DynamicData 2.46.0
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.5.8
luwol03
Post by luwol03 »
Hello chrisb,
sorry for the video. It looks like this is just googledrive. If you download the video, the resolution is very good. And the downloaded file is only 6.2MB large.
How can I get the latest version via brew?
I don't know if it is necessary, I just experienced this bug with all this things in it.
You find a DMG with the latest version here: https://github.com/FreeCAD/FreeCAD-AppI ... kly-builds.
Shalmeneser
Post by Shalmeneser »
:idea:
PicoBox_SHALM.FCStd
(143.95 KiB) Downloaded 43 times
Capture d’écran 2022-11-05 170505.jpg (67.33 KiB) Viewed 1386 times
luwol03
Post by luwol03 »
Shalmeneser wrote: Sat Nov 05, 2022 4:06 pm:idea:
How do you created this body? And how is this related to this bug?
Shalmeneser
luwol03 wrote: Sat Nov 05, 2022 7:40 pm How do you created this body? And how is this related to this bug?
Nothing to do with your problem.
I've created this body from your file (solid), trying to mimic the original object.
