gmsh fails on AirplaneDesign aerofoil shapes
Moderator: oliveroxtoby
alpatters
Post by alpatters »
Hey,
I'm trying to get a 3D mesh working of an aerofoil. Gmsh, CfdOF, AirPlaneDesign.
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * CurvedShapes 1.0.4
  * CfdOF 1.18.0
My (failing) procedure:
1) Using AirPlaneDesign create a NACA aerofoil extruded to 3D.
1a) Checked that it is a "Solid". Geomtery check gives 0 failures or issues.
2) Create a cube surrounding the aerofoil.
3) Cut the aerofoil into the 3D cube. The cut is the surrounding cube that I want to mesh. The aerofoil is a surface, its internal space wont be meshed.
4) Use gmsh to mesh the Cut (the cube with the aerofoil cut out.
5) Open the resulting mesh in Paraview.
At this point Paraview shows that the internal cut of the aerofoil is not an aerofoil but a cube or bounding box of the aerofoil's shape.
So My mesh is the cube with an inner bounding box cut out.
Any help or pointers to get the aerofoil meshed properly for CfdOf ?
oliveroxtoby
Re: gmsh fails on AirplaneDesign aerofoil shapes
Post by oliveroxtoby »
alpatters wrote: Thu Nov 03, 2022 12:25 pm Any help or pointers to get the aerofoil meshed properly for CfdOf ?
Please could you upload a FreeCAD file to test with, otherwise it's really guesswork.
alpatters
Post by alpatters »
Here is the FC file with the objects and my mesh. If you open the mesh in Paraview and slice through it will reveal that the cut is a rectangular shape and not of the aerofoil.
test_aerofoil.FCStd
(628.14 KiB) Downloaded 43 times
oliveroxtoby
alpatters wrote: Thu Nov 03, 2022 5:05 pm Here is the FC file with the objects and my mesh. If you open the mesh in Paraview and slice through it will reveal that the cut is a rectangular shape and not of the aerofoil.
Is this the correct file? When I open it I see a sphere rather than an airfoil.
alpatters
Post by alpatters »
Ah sorry. I've been away for a bit. Looks like that was the wrong file.
I'll upload the correct one
alpatters
Post by alpatters »
Ok maybe some time away works. I got this to work now. Thanks for your help.
