Arch and Draft Workbench failure errors
greg_m
Post by greg_m »
I use FreeCAD for a year or so. I love it.
Used 0.18 (from official Ubuntu repo I think) for a bit, then upgraded to 0.19 (from FreeCAD PPA repo). On 0.19 I've noticed that I can't use Arch workbench as I was getting some errors (I can't remember how it was on 0.18). Kind of forgot about it as I normally don't use Arch.
A few days ago updated it to 0.20.1 from official Ubuntu repo and now Arch and Draft are not working.
Draft workbench would be useful from time to time.
Straight after selecting one of these two workbenches I get the errors as below:
Error pop-up with message:
Workbench failure
<built-in function SoFieldContainer_getField> returned a result with an exception set
And Report view:
22:08:59  Persistent toolbars: Snapper toolbar not managed.
22:08:59  <built-in function SoFieldContainer_getField> returned a result with an exception set
22:08:59  Traceback (most recent call last):
  File "<string>", line 219, in Activated
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1629, in show
    self.setTrackers()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1673, in setTrackers
    self.grid = trackers.gridTracker()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_trackers.py", line 972, in __init__
    pick.style.setValue(coin.SoPickStyle.UNPICKABLE)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3989, in __getattr__
    field = self.getField(name)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3873, in getField
    return _coin.SoFieldContainer_getField(self, name)
and:
22:41:50  Running the Python command 'Arch_Wall' failed:
  File "/usr/share/freecad/Mod/Arch/ArchWall.py", line 337, in Activated
    self.tracker = DraftTrackers.boxTracker()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_trackers.py", line 1249, in __init__
    m.transparency.setValue(0.8)
I found forum threads from a while back about a similar error on Linux which were related to pivy apparently not being compatible with Python 3.10 or something like that.
Is anyone able to help fixing Arch and Draft workbenches please?
I remember 0.19 was working fine on my work PC with Windows 10. I recently upgraded that also to 0.20.1, so will check if that still works fine after the weekend.
My FreeCAD details are as below:
OS: Ubuntu 22.04.1 LTS (XFCE/xubuntu)
Version: 0.20.1.
Branch: unknown
Hash: 22f524c0c755003c12234fab1bad6a9f696b661a
Python 3.10.6, Qt 5.15.3, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.1
  * kicadStepUpMod 10.16.5
  * ExtremeProLight 1.1.3
  * lattice2 1.0.0
  * Defeaturing 1.2.0
  * ExplodedAssembly
  * fasteners 0.4.19
thomas-neemann
Re: Arch and Draft Workbench failure errors
Post by thomas-neemann »
greg_m wrote: Sat Oct 29, 2022 9:36 pm ....
I would try to use the appimage
https://www.freecadweb.org/downloads.php?lang=de
See also this topic about the state of the PPA: https://forum.freecadweb.org/viewtopic.php?f=42&t=69055.
greg_m
Post by greg_m »
I'd prefer to use .deb package rather than .AppImage if possible.
I used 0.19 from PPA, but at the moment I'm using FreeCAD 0.20 from the official Ubuntu repo (which just has been released a few days ago).
In meantime I did some reading about the pivy.
On Ubuntu Jammy it's pivy version 0.6.5-1build6, but on Kinetic (released a week ago) it's 0.6.7-0.1, which quite possibly it should work with FreeCAD. I'm going to try it on VirtualBox first and if that work I'll upgrade my main system.
EDIT: It was actually easier than I thought. I updated pivy to Kinetic version as it has still exactly the same dependencies and it works fine now: both Arch and Draft workbenches.
Problem solved!
wilkinsm
Post by wilkinsm »
FWIW Just reporting that the above mentioned python3-pivy deb update to the kinetic (22.10) version worked for me on Linux Mint 21 as well.
I note Linux Mint 21.1 depends on Debian jammy (22.04 LTS) as well - so I'm guessing that for non containter debian based installations this workaround will probably be needed for quite a while yet.
dpward
Post by dpward »
Fix released for pivy package in Ubuntu 22.04 LTS (and Ubuntu 22.10).
https://bugs.launchpad.net/ubuntu/+sour ... ug/2000840
