[Merged] PR#7655 : Gui: force-hide toolbars + Split sketcher toolbar
paddle
Post by paddle »
https://github.com/FreeCAD/FreeCAD/pull/7655
The offered change is to :
Commit 1 - split the main sketcher toolbar in 2. One for tools that are only in edit mode. One for tools that are only in non-edit-mode.
Commit 2 - This adds the systemwide possibility to hide toolbars at anytime while in a workbench.
Show/hide automatically toolbars depending if we are in edit mode or not.
More specifically it hides : Sketcher-edit-mode, Geometry, constraint, tools, virtualSpace toolbars when in sketcher-not-edit-mode.
And it hides : Sketcher and Structure toolbar when in sketcher-edit-mode
Re: PR#7655 : Gui: force-hide toolbars + Split sketcher toolbar
with the auto hide/show what happens if I manually hide a toolbar, will it be auto shown when I change back and forth from/to edit mode?
paddle
Post by paddle »
adrianinsaval wrote: Fri Oct 28, 2022 9:00 pm with the auto hide/show what happens if I manually hide a toolbar, will it be auto shown when I change back and forth from/to edit mode?
No. If you hide a toolbar it won't show up next. The force hide do not override the preferences.
It was quite painful to get to work right but now it works as expected.
Here's a video :
phpBB [video]
