Sketch_MakeInternals and toponaming
-alex-
Post by -alex- »
realthunder wrote:ping
Hi realthunder, thanks a lot for Sketch MakeInternals feature! This is a great feature, very promising in order to group many features in few master sketches then Pad and pocket quickly :D
However it seems there is a topological issue despite your algorithm. Is it a bug?
Linkstage3-Sketch_MakeInternals-TNP.FCStd
(14.1 KiB) Downloaded 38 times
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Version: 0.20.31507 (Git)
Build type: Unknown
Branch: LinkDaily
Hash: d697dc28623fab496c3175986a04acac94082119
Python version: 3.7.3
Qt version: 5.11.3
Locale: French/France (fr_FR)
Thank you for your great work and your kind attention.
realthunder
Re: Sketch_MakeInternals and toponaming
Post by realthunder »
I have just pushed a few commits to fix this problem. Please sync the try.
-alex-
Post by -alex- »
realthunder wrote: Thu Oct 27, 2022 1:53 pm I have just pushed a few commits to fix this problem. Please sync the try.
Done:
Version: 0.20.31516 (Git)
Build type: Unknown
Branch: LinkDaily
Hash: 2b6bb77ed6671ccb15a583a3e068798aae67d1fa
Qt version: 5.11.3
Tanks for the quick fix, so much appreciated!
The behaviour seems better, but still weird though. The sequence of operations does matter it seems.
See below with the bloc.fcstd file:
1- Stable topology (=TNP OK):
2- Non stable topology (=TNP OK):
Sorry for the noise, it was necessary to sketch and pad again from scratch in files, then the topology is stable with any changes.
For reasonable changes of shape I'm not able to break the topology now :D
FC-Link_sketch-internal_Bloc-TNP-OK.FCStd
(33.12 KiB) Downloaded 30 times
Linkstage3-Sketch_MakeInternals-TNP-OK.FCStd
(13.99 KiB) Downloaded 30 times
Thanks again for this great feature!
realthunder
To minimize uncertainty, please recreate the Pad/Pocket, because there is a bug that I just fixed that may cause the reference to sketch internal geometry got lost in tracking of its name change.
-alex-
Post by -alex- »
realthunder wrote: Thu Oct 27, 2022 10:16 pm To minimize uncertainty, please recreate the Pad/Pocket
Cross post.
You read in my mind, you're too fast ;)
I'm gonna replace the bloc.fcstd file above by the new stable one to avoid misunderstandings.
Your previous fix is already very good.
-alex-
Post by -alex- »
Sketch_MakeInternals is great, unfortunately we cannot use it in Part WB workflow.
Would you plan to expose MakeInternals subelements to the property "Base" of Part_Extrude feature in your branch?
That would be great :)
