BOLTS for architectural components?
Moult
Re: BOLTS for architectural components?
Post by Moult »
It's in IFC4 AU Library.ifc here https://github.com/IfcOpenShell/IfcOpen ... /libraries
There is an example of it used here https://youtu.be/ewvlodE1Nxg?t=620
paullee
Post by paullee »
Thanks Moult. I saw that video on BlenderBim, not aware that it use BOLTS, will have another look.
Moult
Post by Moult »
It doesn't use BOLTS, however I'm proposing to add these dimensions to BOLTS so that it can use BOLTS :) After all, for a lot of architectural design the exact style of the annotation doesn't matter, but it is incredibly useful to know typical dims for furniture.
The steel libraries use BOLTS, naturally :)
In any case right now as an IFC library FreeCAD in theory can still make use of it.
paullee
Post by paullee »
You mean the IFC Project Library?
at - https://youtu.be/ewvlodE1Nxg?t=1548
phpBB [video]
paullee
Post by paullee »
Moult wrote: Fri Mar 03, 2023 1:01 am It doesn't use BOLTS, however I'm proposing to add these dimensions to BOLTS so that it can use BOLTS :) After all, for a lot of architectural design the exact style of the annotation doesn't matter, but it is incredibly useful to know typical dims for furniture.
Thanks, just noted your post after I replied above.
