How to adjust tooltip font size in python console?
mannycrafts
Post by mannycrafts »
Hello, could someone please explain how to adjust the font size for tooltips in the python console( if it's possible to do this)?
It's too tiny to read on my 4k monitor. :(
OS: macOS 10.16
Version: 0.20.29177 (Git)
Locale: C/Default (C)
The tooltip, highlighted
Syres
Re: How to adjust tooltip font size in python console?
Post by Syres »
mannycrafts wrote: Mon Oct 10, 2022 4:26 am Hello, could someone please explain how to adjust the font size for tooltips in the python console( if it's possible to do this)?
It's not a proper fix but that's another story, I just added a line font: 12pt; to the QTootip section of my stylesheet as per:
Tooltip
QToolTip {
    color: #1e1e1e;
    background-color: #b4b4b4;
    /*opacity: 90%; doesn't correctly work */
    padding: 4px;
    border-radius: 3px; /* has no effect */
    font: 12pt;
I've attached a zip of my stylesheet which probably isn't to your taste if you just wanted to swap it to try.
Behave-dark.zip
(10.9 KiB) Downloaded 59 times
You can change it this way:
from PySide2 import QtWidgets
font = QtWidgets.QToolTip.font()
font.pointSize() # returns 9
font.setPointSize(15) # increase to 15
QtWidgets.QToolTip.setFont(font)
mannycrafts
This works perfect, thanks for sharing!
mannycrafts
Syres wrote: Mon Oct 10, 2022 11:40 am
Tooltip
QToolTip {
    color: #1e1e1e;
    padding: 4px;
    font: 12pt;
Thanks for solution @Syres ! I looked to https://wiki.freecadweb.org/Interface_C ... ion#Themes for guidance on how to use your modified theme, but am stuck on how to apply the styles. Could you please explain how to use them, or point me to documentation if any exists?
Adding the snippet in the supposed stylesheet directory on a my Mac didn't seem to work. :(
Syres
Post by Syres »
mannycrafts wrote: Tue Oct 11, 2022 12:32 am I looked to https://wiki.freecadweb.org/Interface_C ... ion#Themes for guidance on how to use your modified theme, but am stuck on how to apply the styles. Could you please explain how to use them, or point me to documentation if any exists?
The best I can do is point you to the Qt docs https://doc.qt.io/qt-5/stylesheet-examples.html, I'm not an expert on stylesheets, I just change one thing at a time until I can get what I want based on the nearest available qss to my needs.
mannycrafts
Very much appreciated!
MisterMaker
Post by MisterMaker »
Is this an addon? Because I cannot find any way to to activate this tooltip.
MisterMaker wrote: Sun Oct 16, 2022 10:23 am Is this an addon? Because I cannot find any way to to activate this tooltip.
You are speaking of the "Python Console" helper?
It is easy as typing in "Python Console" as example:
FreeCAD.Vector.
When you type the "point" and wait some "milliseconds" you will see the "possible completions" and if you select one of them you will see even an help message, and at least on my Linux install, you could use the arrow key to move up and down the list that appear and show the "help message" that are usually "docstrings" or "code comments" present in source code.
MisterMaker
AHA it is capital sensitive. I was just typing in freecad. and nothing happend. :lol:
But checked my theme's on my 4K screen and was pretty good readable.
