Integration of BlenderBIM Features : FreeCAD Arch/BIM - Native IFC
paullee
Re: Integration of BlenderBIM Feaures : FreeCAD Arch/BIM - Native IFC
Post by paullee »
Noted there are several issues in github and items in roadmap, maybe more peoples can help contributing if there is more information there? :)
Testing ifc_tools.create_document(doc), some errors returned, not sure if I am following correctly -
>>> import ifc_tools
>>> doc=FreeCAD.ActiveDocument
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_tools.py", line 67, in create_document
    ifcfile = create_ifcfile()
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_tools.py", line 94, in create_ifcfile
    comp = ifcfile.by_type("IfcCompany")[0]
  File "/home/paullee/.local/lib/python3.10/site-packages/ifcopenshell/file.py", line 363, in by_type
    return [entity_instance(e, self) for e in self.wrapped_data.by_type(type)]
  File "/home/paullee/.local/lib/python3.10/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 3472, in by_type
    return _ifcopenshell_wrapper.file_by_type(self, *args)
RuntimeError: Entity with name 'IfcCompany' not found in schema 'IFC4'
Screenshot from 2023-03-26 00-23-32.png (245.41 KiB) Viewed 3821 times
paullee
Post by paullee »
When recomputing the IfcObject -
00:51:48  Traceback (most recent call last):
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_viewproviders.py", line 187, in setupContextMenu
    super().setupContextMenu(vobj, menu)
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_viewproviders.py", line 81, in setupContextMenu
    if vobj.Object.ShapeMode == "Shape":
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'ShapeMode'
00:51:49  Traceback (most recent call last):
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_objects.py", line 95, in execute
    self.rebuild_classlist(obj)
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_objects.py", line 69, in rebuild_classlist
    obj.Type = ifc_tools.get_ifc_classes(obj, obj.IfcType)
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'IfcType'
00:51:49  Recompute failed! Please check report view.
Screenshot from 2023-03-26 00-52-08.png (243.94 KiB) Viewed 3810 times
yorik
Post by yorik »
Oops.. I think it should be IfcOrganization instead. Will fix.
But @Moult actually suggested me to stay away from filling all this project info at IFC file creation, so with the next commit this should hopefully vanish :)
ebrahim raeyat
Post by ebrahim raeyat »
@yorik Thanks you so much. I found this files and I think these are useful for test. some of those files are very heavy for import.
by U.S. ARMY Corps of Engineers, Engineering Research Developmental Center (ERDC), Construction Engineering Research Laboratory (CERL)
Common Building Information Model Files And Tools
Other examples
paullee
Post by paullee »
Cross-posting, testing import an ifc file in OSArch discussion :-
https://community.osarch.org/discussion ... -17#latest
( BlenderBim Tutorial - Floorplan Update - in 20mins - BlenderBim 23.04.17 )
paullee
Re: Integration of BlenderBIM Features : FreeCAD Arch/BIM - Native IFC
Post by paullee »
@yorik
ifc model imported fine with legacy ifc import, but not Native-IFC :)
Screenshot from 2023-07-05 02-35-10.png (21.59 KiB) Viewed 3280 times
Screenshot from 2023-07-05 02-35-42.png (194.27 KiB) Viewed 3280 times
Screenshot from 2023-07-05 02-37-16.png (189.33 KiB) Viewed 3280 times
yorik
Post by yorik »
Indeed furnishing elements are disabled by default currently... https://github.com/yorikvanhavre/FreeCA ... ls.py#L651
I'll work on that https://github.com/yorikvanhavre/FreeCA ... /issues/50
paullee
Post by paullee »
@yorik Just updated Native-IFC, found some new features, thanks :)
Importing a simple IFC to test / learn how IFC works, found some error as screen capture shown -
01:22:31  Traceback (most recent call last):
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-NativeIFC/./ifc_objects.py", line 129, in execute
    ifc_generator.generate_geometry(obj, cached=cached)
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-NativeIFC/./ifc_generator.py", line 65, in generate_geometry
    elements = get_decomposition(obj)
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-NativeIFC/./ifc_generator.py", line 316, in get_decomposition
    elements = get_decomposed_elements(element, obj)
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-NativeIFC/./ifc_generator.py", line 347, in get_decomposed_elements
    for child in ifcopenshell.util.element.get_decomposition(
<class 'TypeError'>: get_decomposition() got an unexpected keyword argument 'is_recursive'
01:22:31  Recompute failed!
Test_ ArchWall_ To_ IFC_ 11_Simple_ArchSketch.FCStd
(15.55 KiB) Downloaded 53 times
Screenshot from 2023-10-24 01-23-35.png (352.03 KiB) Viewed 2834 times
OS: Fedora Linux 38 (Workstation Edition) (GNOME/gnome-xorg)
Version: 0.21.0.33675 (Git)
Branch: (HEAD detached at 0.21.0)
Hash: 41b058e2087de60dc8fef3d3e68c7d0129e13abf
Python 3.10.12, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.5, OCC 7.6.3
  * BIM 2021.12.0
  * FreeCAD-NativeIFC 2022.10.20
  * Curves 0.6.13
  * Link to SketchArchPlus
Moult
Post by Moult »
You have an outdated ifcopenshell. Try updating?
paullee
Post by paullee »
Thanks @Moult , my IfcOpenShell comes with the FreeCad AppImage, will need to try latest 0.22_pre AppImage then :)
