Integration of BlenderBIM Features : FreeCAD Arch/BIM - Native IFC
paullee
Re: Integration of BlenderBIM Feaures : FreeCAD Arch/BIM
Post by paullee »
I have long used AppImage on Fedora, with built-in IfcOpenShell :D
paullee
Post by paullee »
Trying to understand the code, ifc_tools.py get_children reads -
( https://github.com/yorikvanhavre/FreeCA ... #L110-L124 )
def get_children(obj, ifcfile):
    """Returns the direct descendants of an object"""
    ifcentity = ifcfile[obj.StepId]
    children = []
    for rel in getattr(ifcentity, "IsDecomposedBy", []):
        children.extend(rel.RelatedObjects)
    for rel in getattr(ifcentity, "ContainsElements", []):
        children.extend(rel.RelatedElements)
    for rel in getattr(ifcentity, "HasOpenings", []):
        children.extend([rel.RelatedOpeningElement])
    for rel in getattr(ifcentity, "HasFillings", []):
        children.extend([rel.RelatedBuildingElement])
    return filter_elements(children)
Googling BuildingSmart + IsDecomposedBy or ContainsElements seems return pages not directly relevant. Any hint ? Thanks.
paullee
Post by paullee »
Latest update, working expand children working :)
( some error in report )
Seems there is no hint which objects have children until user right click on every object, can have different object icon ? Thanks.
Screenshot from 2022-12-05 01-33-55.png (195.56 KiB) Viewed 2014 times
Screenshot from 2022-12-05 01-37-34.png (217.02 KiB) Viewed 2020 times
Screenshot from 2022-12-05 01-46-40.png (230.69 KiB) Viewed 2020 times
yorik
Post by yorik »
It's complicated because each IFC file is different :) schependomlaan is also my base example..
paullee wrote: Sat Dec 03, 2022 2:20 pm Googling BuildingSmart + IsDecomposedBy or ContainsElements seems return pages not directly relevant. Any hint ? Thanks.
No and I also found weird things in different files... But still not sure how best to deal with this and have a reliable method to get children. Also because the question "what is a child" is complicated within IFC :)
ragohix769 wrote: Fri Dec 02, 2022 12:49 am In my system ifcopenshell is already installed:
Indeed I'm not sure the addon manager can install stuff on a snap version of FreeCAD.. I'd suggest:
1) install ifcopenshell via pip OUTSIDE FreeCAD (in a terminal for ex) - I think you did this already
2) verify if ifcopenshell is available within FreeCAD (
import FreeCAD
in the python console of FreeCAD)
3) If not, verify what python paths are available to FreeCAD (
import sys; print(sys.path)
4) Verify where ifcopenshell is installed (
import ifcopenshell;print(ifcopenshell.__file__
from a terminal where you launch 'python')
5) Verify that the path given is in the sys.path informed in point 3). If not, we might need to adapt something in the snap packages I think...
ragohix769
Post by ragohix769 »
ifcopenshell it's correctly installed in my system, that's for sure also because in the Daily (last update 1 month ago) version (in PPA repos) of FreeCAD that I still use, nativeifc it's working I can import ifc files without any problem. Here is the log from the shell
:~$ pip install ifcopenshell
Requirement already satisfied: ifcopenshell in ./.local/lib/python3.8/site-packages (0.7.0)
If I try to see if ifcopenshell is present in FreeCAD via python console (in FC) it return this:
 IfcOpenShell was not found on this system. IFC support is disabled.
Visit https://wiki.freecadweb.org/IfcOpenShell to learn about installing it.
So maybe ifcopenshell should be included in the package to call it under local snap/ paths, because ifcopenshell in the system it's not seen by snap version.
This is another (big) advantage of PPA packages, IMHO, pity that was abandoned.
paullee
Post by paullee »
A minor observation:-
Just try to update the Add-on again, have noted that the reported date of current installation is not updated.
I have just updated, restarted, and noted the date of latest/current update is still outdated, a bit confused :lol:
Screenshot from 2022-12-11 12-21-38.png (19.57 KiB) Viewed 1795 times
paullee
Post by paullee »
Unfortunately, importing / opening the IFC Schependomlaan.ifc crash FC, everytime when it seems import / opening reach almost 100% :roll:
Screenshot from 2022-12-11 12-21-38.png (19.57 KiB) Viewed 1776 times
OS: Fedora Linux 36 (Workstation Edition) (GNOME/gnome)
Version: 0.21.30345 (Git)
Hash: f42a47aa0fd8c4f34ef63c185d9f29b9b6e84737
  * dodo 1.0.0
  * DynamicData 2.46.0
  * ArchTextures
  * BOLTSFC.backup1666323893.5041647
  * BOLTSFC
  * FreeCAD-BlenderBIM.backup1666328110.015535
  * FreeCAD-BlenderBIM.backup1666737837.420096
  * FreeCAD-BlenderBIM 2022.10.20
  * 3rd link to Paul
  * 3rd link to SketchArchPlus
  * BIM.backup1670731522.690569
  * BIM 2021.12.0
paullee
Post by paullee »
Curiously, after a few attempt, it now open (not sure if it is to do with I have rebooted the system) but crash when i try expand Children.
FreeCAD (copy).log
(22.56 KiB) Downloaded 60 times
EDIT - Then I try closed my FireFox and it expand Children without problem; and then I re-open FireFox, and when the latter is up, FC crahes; not enough memory ? :roll:
Screenshot from 2022-12-11 18-21-43.png (66.22 KiB) Viewed 1723 times
Screenshot from 2022-12-11 18-30-59.png (297.69 KiB) Viewed 1723 times
ragohix769
paullee wrote: Sun Dec 11, 2022 10:02 am EDIT - Then I try closed my FireFox and it expand Children without problem; and then I re-open FireFox, and when the latter is up, FC crahes; not enough memory ? :roll:
If it's a memory problem and you have a swap file enabled (like is very common in every standard installation) IMHO it's difficult having a crash, you should have a continuous read/write on disk rather then a crash. Anyway you can log memory in realtime to see if that's the problem, open the shell and use a top or htop command on background when running programs.
I cannot use or test anymore NativeIFC because I cannot install or use ifcopenshell with the snap package (I had to use snap because the daily on PPA repos it's not updated anymore :-( ), so for me it's not possibile to try anything on edge with this addon :-(
paullee
Post by paullee »
Thanks for the heads-up, will have a look if the system has read/write swap on native IFC importing.
Not sure if you can use AppImage, which has built-in IfcOpenShell, and I have no problem on Fedora 36.
Now, (without running firefox) I have expanded all children in my last attempt. 2 weird things though:-
1. In an earlier attempt to import, unknown to me what I had done during the process, I had expanded a few objects, but found the rest of objects had no more options to expand :roll:
(see screencapture - can't capture the context menu which has no 'expand children' )
(No problem in my last attempt w/o Firefox as mentioned above)
2. There are a few cubes, large and small, associated with the IFC objects.
(see screencapture)
Screenshot from 2022-12-11 20-22-52.png (323.18 KiB) Viewed 1664 times
Screenshot from 2022-12-11 20-19-07.png (304.24 KiB) Viewed 1664 times
Screenshot from 2022-12-11 20-18-11.png (206.47 KiB) Viewed 1664 times
Screenshot from 2022-12-11 20-18-28.png (201.66 KiB) Viewed 1664 times
