Integration of BlenderBIM Features : FreeCAD Arch/BIM - Native IFC
ragohix769
Integration of NativeIFC Feaures in FreeCAD Arch/BIM
Post by ragohix769 »
I've tried too and I confirm Paul, it's augmented: now to open the same file it takes 277 seconds (4,6 min) and saving to *.FCStd it's now about 48,1 MB.
Log:
https://pastebin.com/gUQLMYeq
OS: Ubuntu 20.04.5 LTS (KDE/plasma)
Version: 0.21.
Branch: unknown
Hash: 7c51aa9749eddcfc0981feea3c3468560b88db22
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: Italian/Italy (it_IT)
  * FreeCAD-BlenderBIM 2022.10.20
  * BIM 2021.12.0
yorik
Re: Integration of BlenderBIM Feaures : FreeCAD Arch/BIM
Post by yorik »
paullee wrote: Wed Oct 26, 2022 12:03 am Latest version requires about 6 min to import the same ifc on my i3.
ragohix769 wrote: Wed Oct 26, 2022 1:04 am I confirm Paul, it's augmented: now to open the same file it takes 277 seconds
That is because I am experimenting with different import strategies... There will still be highs and lows in the coming weeks, don't expect stability or constant improvement just yet ;)
But looking at your screenshot @paullee you are not using the bb importer... These arch components are made by the Arch importer
ragohix769
yorik wrote: Wed Oct 26, 2022 7:06 am That is because I am experimenting with different import strategies... There will still be highs and lows in the coming weeks, don't expect stability or constant improvement just yet ;)
Ok ok Yorik, it was just to see that a NativeIFC Authoring it's an implementation already in progress in FreeCAD, that's really cool! :D
If you need any testing, please let me know without problem 8-)
paullee
Post by paullee »
Oops :)
So, there is still no pop up dialog box asking which importer to use :roll:
ragohix769
paullee wrote: Wed Oct 26, 2022 3:13 pm
Oops :)
Me too here, no importer selectable:
#### To test
* Run FreeCAD
* `File` → `Open` or `File` → `Insert`, select an IFC file
* Select the BlenderBIM importer (bb_import)
Ok [EDIT]
I think that I know what's going on, at least in my machine/installation.
If do Open>File>selecting the IFC file, there is no importer selection, but the file is imported superfast in 9-10 seconds very clean (in my Ryzen7:16cores@32_GB machine), and if I save to *.FCStd it's only 13 MB.
But... If I clic on recent files on startup, then the importer I think it's not used, I dont' know why, but it's used instead some Arch component to import, mega slow and a mess on error on report review. And if you save it, it creates a file large same like the the original *.IFC
paullee
Post by paullee »
ragohix769 wrote: Wed Oct 26, 2022 3:16 pm I think that I know what's going on, at least in my machine/installation.
Confirmed, I suspect something is wrong, and both File>Open, or New>Import, import superfast - about 1min.
Then, noted Ragohix's finding above about opening the ifc in 'recent files' in startup; confirm in this case it creates lots of Arch Component, i.e. 'existing' ifc importer.
Screenshot from 2022-10-27 00-44-20.png (170.43 KiB) Viewed 1630 times
chennes wrote: Tue Oct 25, 2022 2:37 pm OK, then let's try tweaking it to get some more output:
import subprocess
import addonmanager_utilities as utils
python_exe = utils.get_python_exe()
args = [python_exe, '-m', 'pip', 'install', '--disable-pip-version-check', '--target', '/home/beast/snap/freecad/common/AdditionalPythonPackages', 'ifcopenshell']
proc = subprocess.run(args)
print(proc.stdout.decode())
print(proc.stderr.decode())
Result:
AttributeError: 'NoneType' object has no attribute 'decode'
yorik
Post by yorik »
ragohix769 wrote: Wed Oct 26, 2022 3:16 pm But... If I clic on recent files on startup, then the importer I think it's not used, I dont' know why, but it's used instead some Arch component to import, mega slow and a mess on error on report review. And if you save it, it creates a file large same like the the original *.IFC
Aha... I think I also see what can happen: I think both importers use exactly the same desciption for IFC files, and there is some mix-up done somewhere... I'll try changing a bit the one in bb
JFYI, chennes and I have been working to get the snap edge to play nice installing ifcopenshell and found an issue. Hopefully it will get addressed in https://github.com/FreeCAD/FreeCAD-snap/issues/68 so testers can use snaps for testing this workbench as well.
paullee
Post by paullee »
Tested latest commit (5 days ago by carlopav)
Noted the File-Open / File-Import dialog box provide IFC-Native option to select :) Right click, Reveal Children works, and an Site object is revealed - time consuming though :D
Further Reveal Children though after revealing another child object (Building?) crash FC.
Screenshot from 2022-11-04 06-31-01.png (36.95 KiB) Viewed 1324 times
Screenshot from 2022-11-04 06-33-44.png (244.28 KiB) Viewed 1324 times
Screenshot from 2022-11-04 06-51-59.png (257.5 KiB) Viewed 1324 times
OS: Fedora Linux 36 (Workstation Edition) (GNOME/gnome)
Version: 0.21.30345 (Git)
Hash: f42a47aa0fd8c4f34ef63c185d9f29b9b6e84737
  * dodo 1.0.0
  * DynamicData 2.46.0
  * ArchTextures
  * BOLTSFC.backup1666323893.5041647
  * BOLTSFC
  * FreeCAD-BlenderBIM.backup1666328110.015535
  * FreeCAD-BlenderBIM.backup1666737837.420096
  * 3rd link to SketchArchPlus
