Is "Basic Part Design Tutorial" in line with actual Part Design workflow?
Roy_043
Re: Is "Basic Part Design Tutorial" in line with actual Part Design workflow?
Post by Roy_043 »
This is on my todo list. I'll try to have a look later this week.
Roy_043 wrote: Mon Nov 07, 2022 4:52 pm This is on my todo list. I'll try to have a look later this week.
Thanks, I will review a little the code, for sure there are some errors, yesterday I've tried to avoid some images using a schematic with "named points", mimicking the GUI appearance (with standard theme).
I will pospone every other edits after I ear some new for you, so there is not too much noise.
My residual problem is to add the produced file, adding pd_tut_xxxx.FCStd and pd_tut_xxxx.fcstd will raise an error, there is a special procedure?
edwilliams16
Post by edwilliams16 »
Here's a few thoughts. I was reluctant to directly edit your draft.
  • Shrink the drawing
  • In create the first sketch, explain about two escapes and the option to right click here rather than later. I remember being frustrated by this when learning.
  • The symmetrical constraint centers the top edge about the origin (not just the Y-axis). This allows us to take advantage of the model's symmetry in later mirror operations.
  • Sketch002 is on the XZ-plane.
  • We could also use the Base YZ plane as the symmetry plane - which may be easier to visualize.
  • Sketch003 is on the XY-plane
  • Show a figure for Sketch003 e.g.
Screen Shot 2022-11-09 at 8.41.08 AM.png (17.49 KiB) Viewed 1364 times
  • In Sketch004 for P3/P4 a vertical constraint could replace either of the point-on-line constraints. Using all three would be redundant.
  • Pocket001 - here use 17mm symmetric to plane. The length/length2 option would be useful were it not symmetric - which might be good to note anyway.
edwilliams16 wrote: Wed Nov 09, 2022 7:09 pm Here's a few thoughts. I was reluctant to directly edit your draft.
Hello, first of all many thanks, for the review and for tutoring me.
I have tried to implement some of your suggestions, and modified the page.
Sorry I don't guess completely all points, due for sure to my poor knowledge of both Sketcher and English. :D
I will try to be puncutal, see below:
Shrink the drawing
Done
Done, but some text revision is needed, as the original text is referring to the polyline tool, due to "low knowledge" of Sketcher I don't know if we could generalize the sentence for other tools too. Could you please suggest what is the best way to explain this thing, I have copied the notes and joined in one place.
Probably we should name it in some meaningful manner, (I added Caveats) and/or add some other notes.
Yes this make sense, I have to modify some drawings, noted down for now.
Done
Some proposal for the image?
Done
Where?
I could not get the point here, could you kindly explain me more extensively ?
Proposed change?
Many Thanks and Regards
Shalmeneser
Post by Shalmeneser »
... part shown in the Drawing below. -> https://wiki.freecadweb.org/Glossary#Drawing ?
If you had checked Auto constraints in Edit controls window in sketcher
Select XY_Plane in from the Combo view list. Press OK
or
Select XY_Plane from the 3D view. No need to press OK (except in v0.19).
Don't place points on X axis as the Solver will ...
Once done press ESC or Right-click to exit ...
Symmetrical constraint -> I prefer to put P2 and P3 on X-axis then set them symmetrical around Y-axis
Select line defined by P2 to P3 in Fig: SKC1. -> Select one horizontal line ...
Select line defined by P3 to P4 in Fig: SKC1 -> Select one vertical line ...
How to leave master sketch ?
___
for the moment
OS: Linux Mint 20.3 (MATE/mate)
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438
Python version: 3.8.8
Qt version: 5.12.9
Locale: French/France (fr_FR)
Shalmeneser wrote: Sat Nov 12, 2022 2:02 pm ...
Thanks I will work on it probably tomorrow.
EDIT: @edwilliams16 has done most of these corrections. (Thanks Ed) :D
I have some doubts:
  1. As noted by @edwilliams16 for Sketch003 an image of the sketch should be added, better to do using points, so there is no ambiguity and maybe refer to the point of Sketch003, reference to P1 on image SK2_2 seems almost clear.
  2. I have modified the page explicitly using Stepxx instead of numbers, as nested list will make things more involuted, it seems more clear (I know that we are not newbies, but I think the main scope of the tutorial is to guide a newbie through the points, without repeating explanations too much).
  3. How to ad the file to show the result, I've had error messages when I,ve tried with FCStd and fcstd extensions, bu no luck.
I have had one reply from an user that have found it decent, maybe wait for other remarks.
It should be almost decent to ask for a proper link in the Tutorial page?
Roy_043
Post by Roy_043 »
You cannot upload an FCStd file to the Wiki.
You can attach it to a forum post:
Basic_Sketcher_Tutorial
Or do a PR to have it added to https://github.com/FreeCAD/Examples:
Basic_Part_Design_Tutorial
Roy_043
Post by Roy_043 »
onekk wrote: Sun Nov 13, 2022 11:10 am a proper link in the Tutorial page?
Don't worry, that will be added in due course.
Roy_043 wrote: Sun Nov 13, 2022 6:33 pm
Thanks I will try to make a PR, but in the GitHub site there is an optional way saying to ask on a forum post, but link seems not working.
