I'll take a look at your code. Here's my script:
"""Script to replicate Part Design Tutorial Example.
https://wiki.freecadweb.org/Basic_Part_Design_Tutorial
This code was written as an sample code
Author: Carlo Dormeletti
Copyright: 2022
Licence: CC BY-NC-ND 4.0
import os
import FreeCAD # noqa
import FreeCADGui # noqa
import Sketcher
import Part
from FreeCAD import Placement, Rotation, Vector # noqa
def activate_doc(doc_name):
"""Activate a specific document."""
FreeCAD.setActiveDocument(doc_name)
FreeCAD.ActiveDocument = FreeCAD.getDocument(doc_name)
FreeCADGui.ActiveDocument = FreeCADGui.getDocument(doc_name)
print(f"Document: {doc_name} activated")
def clear_doc(doc_name):
"""Clear the document deleting all the objects."""
doc = FreeCAD.getDocument(doc_name)
for obj in doc.Objects:
try:
doc.removeObject(obj.Name)
except Exception:
pass
def setview(doc):
"""Rearrange View."""
try:
doc_v = FreeCAD.Gui.activeView()
FreeCAD.Gui.SendMsgToActiveView("ViewFit")
doc_v.viewAxometric()
except Exception:
pass
def check_exist(doc_name):
"""Check the existence of a FC document named doc_name.
If it not exist create one.
try:
except NameError:
doc = FreeCAD.newDocument(doc_name)
return doc
# CODE start here
# Create an appropriate place for the final file.
home_dir = os.path.expanduser('~')
dirpath = os.path.join(home_dir, 'pd_tut')
if os.path.exists(dirpath):
pass
else:
# create path
os.mkdir(dirpath)
# Some methods to ease the work
def createPDBody(doc, bodyname, lcs=False):
"""Create new Part Design Body."""
newBody = doc.addObject("PartDesign::Body", bodyname)
if lcs is True:
# add an LCS at the root of the Part, and attach it to the 'Origin'
lcs0 = newBody.newObject('PartDesign::CoordinateSystem', 'LCS_0')
lcs0.Support = [(newBody.Origin.OriginFeatures[0], '')]
lcs0.MapMode = 'ObjectXY'
lcs0.MapReversed = False
newBody.recompute()
doc.recompute()
return newBody
def sketchPolyLine(vertexList, closed = True, addHVConstraints = True):
geoList = []
conList = []
npts = len(vertexList)
for i in range(npts - 1):
geoList.append(Part.LineSegment(vertexList[i], vertexList[i+1]))
if closed:
geoList.append(Part.LineSegment(vertexList[-1], vertexList[0]))
conList.append(Sketcher.Constraint('Coincident', i, 2, i + 1, 1))
if closed:
conList.append(Sketcher.Constraint('Coincident', npts - 1, 2, 0, 1))
if addHVConstraints:
for i, ls in enumerate(geoList):
if abs(ls.tangent(0)[0].y) < 1e-14:
conList.append(Sketcher.Constraint('Horizontal', i))
elif abs(ls.tangent(0)[0].x) < 1e-14:
conList.append(Sketcher.Constraint('Vertical', i))
return (geoList, conList)
def make_base_sketch(doc, bd_name, sk_name, l1, h1, dim_const=True):
#rectangular sketch
sk = doc.getObject(bd_name).newObject('Sketcher::SketchObject', sk_name)
p1 = Vector(0, 0, 0)
p2 = Vector(l1, 0, 0)
p3 = Vector(l1, h1, 0)
p4 = Vector(0, h1, 0)
geoList, conList = sketchPolyLine([p1, p2, p3, p4])
(line0, line1, line2, line3) = sk.addGeometry(geoList, False)
sk.addConstraint(conList)
sk.addConstraint(Sketcher.Constraint('Symmetric',0,1,0,2,-1,1))
if dim_const is True:
con_num = sk.ConstraintCount
sk.addConstraint(Sketcher.Constraint('DistanceX', line2, 1, line2, 2, l1))
sk.addConstraint(Sketcher.Constraint('DistanceY', line1, 2, line1, 1, h1))
sk.renameConstraint(con_num, u'length')
sk.renameConstraint(con_num + 1, u'width')
sk.recompute()
return sk
def make_sk1(doc, bd_name, sk_name):
"""Make sketch 1."""
sk.MapMode = 'FlatFace'
sk.Support = (doc1.getObject('YZ_Plane'), [''])
# Lengths
h1 = 26.00
l1 = 10.00 # fake value we assign it later
l2 = 5.00
# we draw it using counterclockwise order
p2 = Vector(0, h1, 0)
p3 = Vector(-l2, h1, 0)
p4 = Vector(-l1, 0, 0)
sk.addExternal("base_sketch", "Edge2") #-3
conList.append(Sketcher.Constraint('Coincident', -3, 2, line2, 2)) #ext reference
#dimensional constraints (putting in conList fails!?)
sk.addConstraint(Sketcher.Constraint('DistanceY', line0, 1, line0, 2, h1))
sk.addConstraint(Sketcher.Constraint('DistanceX', line1, 1, line1, 2, -l2))
sk.recompute()
return sk
def make_sk2(doc, bd_name, sk_name):
sk.Support = (doc1.getObject('XZ_Plane'), [''])
l1 = 5.00
l2 = 11.00
h1 = 26 #fake
w1 = 26.5 #fake
p1 = Vector(-w1, h1, 0)
p2 = Vector(-w1 + l2, h1, 0)
p3 = Vector(-w1 + l2, h1 - l1, 0)
p4 = Vector(-w1, h1 - l1, 0)
sk.addExternal("base_sketch", "Edge3") #-3
sk.addExternal("sketch_1", "Edge3") #-4
conList.append(Sketcher.Constraint('PointOnObject', -3, 1, line3)) #ext reference
conList.append(Sketcher.Constraint('PointOnObject', -4, 1, line0)) #ext reference
sk.addConstraint(Sketcher.Constraint('DistanceY', line3, 1, line3, 2, l1))
sk.addConstraint(Sketcher.Constraint('DistanceX', line0, 1, line0, 2, l2))
sk.recompute()
#doc.recompute()
return sk
def make_sk3(doc, bd_name, sk_name):
"""Make sketch 3."""
l1 = 16.7
l2 = 7
w1 = 26.5 #fake
p1 = Vector(-w1, l1, 0)
p2 = Vector(-w1 + l2, l1, 0)
p3 = Vector(-w1 + l2, 0, 0)
p4 = Vector(-w1, 0, 0)
conList.append(Sketcher.Constraint('Coincident', -3, 1, line3, 1)) #ext reference
sk.addConstraint(Sketcher.Constraint('DistanceY', line1, 2, line1, 1, l1))
sk.recompute()
#doc.recompute()
return sk
def make_sk4(doc, bd_name, sk_name):
"""Make sketch 4."""
d1 = 7
d2 = 17
p1 = Vector(-11, 19, 0) #fake approx
p2 = Vector(-22, 5, 0) #fake approx
p3 = Vector(0, 5, 0) #fake approx
p4 = Vector(0, 19, 0) #fake approx
geoList, conList = sketchPolyLine([p1, p2, p3, p4], closed = True)
sk.addExternal('sketch_1', 'Edge3')
conList.append(Sketcher.Constraint('PointOnObject', 0, 1, -3)) #ext reference
conList.append(Sketcher.Constraint('PointOnObject', 1, 1, -3)) #ext ref
conList.append(Sketcher.Constraint('PointOnObject', -1, 1, 2)) #yaxis
sk.addConstraint(Sketcher.Constraint('Distance',-3,2,line0,2,d1))
sk.addConstraint(Sketcher.Constraint('Distance',line0,2,line0,1,d2))
sk.recompute()
return sk
# Create the document
DOC1_NAME = 'pd_tut_ew'
doc1 = check_exist(DOC1_NAME)
doc1.clearDocument()
activate_doc(DOC1_NAME)
bd1_name = 'body1'
# We need a body where to place the Features
pd1 = createPDBody(doc1, bd1_name)
#build sketches
base_sk_name = "base_sketch"
base_sketch = make_base_sketch(doc1, bd1_name, base_sk_name, 53.00, 26.00)
base_sketch.Visibility = False
#base_sketch.addConstraint(Sketcher.Constraint('Symmetric',0,1,0,2,-1,1))
sk1_name = 'sketch_1'
sk1 = make_sk1(doc1, bd1_name, sk1_name)
sk1.Visibility = False
sk1.recompute()
sk2_name = 'sketch_2'
sk2 = make_sk2(doc1, bd1_name, sk2_name)
sk2.Visibility = False
sk3_name = 'sketch_3'
sk3 = make_sk3(doc1, bd1_name, sk3_name)
sk3.Visibility = False
sk4_name = 'sketch_4'
sk4 = make_sk4(doc1, bd1_name, sk4_name)
sk4.Visibility = False
#first pad
pa1 = pd1.newObject('PartDesign::Pad', 'pad1')
pa1.Type = u"Length"
pa1.AlongSketchNormal = True
pa1.Midplane = True
pa1.Profile = sk1
pa1.setExpression('Length', u'base_sketch.Constraints.length')
pa1.recompute()
# here
#pd1.recompute()
#first pocket
pk1 = pd1.newObject('PartDesign::Pocket', 'pocket1')
pk1.Type = u'ThroughAll'
pk1.Profile = sk2
pk1.AlongSketchNormal = True
#pk1.ReferenceAxis = (sk2,['N_Axis'])
pk1.Reversed = True
pd1.recompute()
#second pad
pa2 = pd1.newObject('PartDesign::Pad', 'pad2')
pa2.Type = u"Length"
pa2.AlongSketchNormal = True
pa2.Profile = sk3
pa2.setExpression('Length',u'base_sketch.Constraints.width')
#mirror pocket and second pad
pa3 = pd1.newObject('PartDesign::Mirrored', 'Mirrored_Pad')
pa3.Originals = [pk1, pa2]
pa3.MirrorPlane = (doc1.getObject('YZ_Plane'), [''])
pa3.Refine = True
pa3.recompute()
pd1.Tip = pa3
pd1.recompute()
#final pocket
pk2 = pd1.newObject('PartDesign::Pocket', 'pocket1')
pk2.Type = u'Length'
pk2.Profile = sk4
pk2.Midplane = True
pk2.AlongSketchNormal = True
pk2.Length = 17
pk2.Refine = True
doc1.recompute()
doc1.FileName = os.path.join(dirpath, f"{DOC1_NAME}.FCStd")
doc1.Comment = "File produced using PD Scripting"
doc1.CreatedBy = "Dormeletti Carlo"
doc1.save()
setview(doc1)
