FemByGen Workbench - Parametric FEM Analysis
Moderator: bernd
Re: FemByGen Workbench - Parametric FEM Analysis
For convenience here's the fembygen Results.py source: https://github.com/Serince/FEMbyGEN/blo ... Results.py
Hi Markus,markus_freecad wrote: ↑Fri Sep 30, 2022 9:51 am Hi,
I have problems with an easy test example.
At the end there is no result matrix because of this.
Could anyone help?
Kindly regards
Markus
It was a bug that occurred only for an analysis container (one loadcase). I fixed it. Can you update the Fembygen workbench?
All the best,
Serdar
Hello Sedar,
Congratulations on the release of the workbench, FEMByGen & Beso are putting the 'Aided' in The CAD!
Please Note the error & the file are attached/Included (Forum says file too large) https://drive.google.com/file/d/1JNfPuK ... sp=sharing.
Basically its a bracket analysis & It hang up after the results button was triggered.
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
* A2plus 0.4.59d
* Assembly3 0.11.3
* Assembly4 0.12.4
* FEMbyGEN 1.1.0
* lattice2 1.0.0
* ModernUI
- Screenshot Comms_03.png (71.66 KiB) Viewed 13052 times
Hi,Outsourced wrote: ↑Sat Oct 08, 2022 6:15 am Hello Sedar,
Congratulations on the release of the workbench, FEMByGen & Beso are putting the 'Aided' in The CAD!Please Note the error & the file are attached/Included (Forum says file too large) https://drive.google.com/file/d/1JNfPuK ... sp=sharing.Code: Select all
OS: Windows 10 Version 2009 Word size of FreeCAD: 64-bit Version: 0.20.1.29410 (Git) Build type: Release Branch: releases/FreeCAD-0-20 Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563 Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3 Locale: English/Australia (en_AU) Installed mods: * A2plus 0.4.59d * Assembly3 0.11.3 * Assembly4 0.12.4 * FEMbyGEN 1.1.0 * lattice2 1.0.0 * ModernUI
Probably, one of your analysis is not completed. Can you check all results in the their generated file, not in master file. My mean, in the same folder there are some folders which name is Gen1 , Gen2... open that freecad files to check results probably one of them is not completed. In the next update, I will add better error handling to see details. I coudn't even open your model when I open your model, because my notebook freezed.
I suggest that modelling 2D this kind of simulattion. If thickness and the other sizes are too different, 2D results are more trustable. After sketch, you can convert your wires to surface in part menu. Then you can define thickness in FEM workbench.
All the best,
Thanks for the reply, I will look into 2d FEM sometime in the near future, I just thought with the subtractions generated in beso, it would be better to break down the simulation to 1mm for the ease of using pressure loading and the finished part could easily be traced from 1mm sim. I havent trainned in 2d as of yet but understand the concept line & triangular loading mmm can calculix even do triangular loading.....too late to study atm. Lol
I have done for you maybe you can write a tutorial document in wiki .Outsourced wrote: ↑Mon Oct 10, 2022 11:31 am Thanks for the reply, I will look into 2d FEM sometime in the near future, I just thought with the subtractions generated in beso, it would be better to break down the simulation to 1mm for the ease of using pressure loading and the finished part could easily be traced from 1mm sim. I havent trainned in 2d as of yet but understand the concept line & triangular loading mmm can calculix even do triangular loading.....too late to study atm. Lol
All the best
Hello Serince,
Sadly my time with experimental features is out of reach for a while, due to major life & death renovations. So there are 6 downloads on the above file perhaps the follows could contribute a little. Keep up the good work I will be back in approx 6 months.
Got some issues under snap-version.
Error:
The example work.
My testfile works without changes under:
So i think it is related to something in the snap-version.
OS: Ubuntu Core 20 (Budgie:GNOME/budgie-desktop)
Version: 0.21.30988 (Git) Snap 426
Hash: 0679c40d26ab2f48ca0f8cd0c34ac3bdbdacec54
Python 3.8.10, Qt 5.15.5, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
* CurvedShapes 1.0.3
* ArchTextures
* MOOC 2022.4.21
* EM
* Pyramids-and-Polyhedrons
* freecad.gears.backup1667327399.8652053
* ModernUI.backup1662298220.4497876
* POV-Ray-Rendering
* CfdOF 1.17.5
* CADExchanger
* MOOC.backup1662298235.0115418
* InventorLoader
* fasteners 0.3.50
* sheetmetal 0.2.57
* InventorLoader.backup1667327052.9532268
* BIM 2021.12.0
* ExplodedAssembly
* OSE3dPrinter
* ModernUI
* ose-piping
* lattice2 1.0.0
* dodo 1.0.0
* Curves 0.5.2
* FEMbyGEN 1.1.0
* 3D_Printing_Tools
* freecad.gears
* MeshRemodel 1.8919.0
07:45:30 Please delete earlier generations: Gen1 already exist in the folder
OS: Ubuntu 20.04.5 LTS (Budgie:GNOME/budgie-desktop)
* InventorLoader 1.3.0
* FEMbyGEN 1.1.0
Hi,PMMA wrote: ↑Fri Nov 18, 2022 6:50 am
Error:So i think it is related to something in the snap-version.Code: Select all
Actually, the error message explained the condition. When you press the generate button, generation folders are created in the same path as your file. If you want to again generate, these folders (Gen1, Gen2....) must be deleted. Please press the "Delete earlier generations" button at the bottom of the same screen or delete the Gen1, Gen2 ... folders in the FreeCAD master model file path. If you are getting an error message despite doing this, could you try moving your master file to another folder?
Apart from that, I made some changes, such as multicore operations. can someone test the dev branch?
All the best,
1. Delete earlier generations [x]
2. Move master file [x]
Cannot rename project file to backup file.
I have to save my files especially with the ending .FCStd, otherwise i get a hidden File.
Maybe its related to that.
Under the AppImage your workbench runs fine.
I like it
My snapversion also gives me the error:Actually, the error message explained the condition. When you press the generate button, generation folders are created in the same path as your file. If you want to again generate, these folders (Gen1, Gen2....) must be deleted. Please press the "Delete earlier generations" button at the bottom of the same screen or delete the Gen1, Gen2 ... folders in the FreeCAD master model file path. If you are getting an error message despite doing this, could you try moving your master file to another folder?
I like it
