PartDesign Thickness - inwards by default
I'd like to suggest a small change. I think that it would be better to set the "Make thickness inwards" option of PartDesign Thickness to be checked by default. That's because such hollowing operations in CAD software are usually performed inwards and it's easy to make a mistake and apply this operation in the opposite direction.
What do you think about this ? Are there any reasons to keep this option unchecked by default ?
Re: PartDesign Thickness - inwards by default
+1
For injection-moulded parts you usually design the mould side (outer surface) of a part and use inward thickness to get the die side.
I would start parts to be 3D-printed from the outside as well.
And for deep-drawn sheet metal parts in contrast you usually design the die side and add outward thickness.
I bet the majority of parts represent moulded or 3d-printed parts, that's why I second this change.
- adrianinsaval
To implement this, would it be sufficient to replace this piece of code in src/Mod/PartDesign/Gui/TaskThicknessParameters.ui:
with:
or is it more complicated ?
<widget class="QCheckBox" name="checkReverse">
<property name="text">
<string>Make thickness inwards</string>
</property>
</widget>
<property name="enabled">
<bool>true</bool>
</property>
</property>
</widget>
+1
I seem to recall that thickness is set to outward because OCC is handling better outward than inward which fails more often.
But yes inward should be default.
@paddle Do you know if that code change above is sufficient to change this default setting ?
This is not enough IMO.NewJoker wrote: ↑Tue Sep 13, 2022 8:54 am To implement this, would it be sufficient to replace this piece of code in src/Mod/PartDesign/Gui/TaskThicknessParameters.ui:
with:Code: Select all
<widget class="QCheckBox" name="checkReverse"> <property name="text"> <string>Make thickness inwards</string> </property> </widget>
or is it more complicated ?Code: Select all
<widget class="QCheckBox" name="checkReverse"> <property name="enabled"> <bool>true</bool> </property> <property name="text"> <string>Make thickness inwards</string> </property> </widget>
If I'm correct, also set it to true here : https://github.com/FreeCAD/FreeCAD/blob ... ss.cpp#L48
EDIT : Most probably even this last change is needed.
I think that code will only change the UI element default state but it won't set the actual command boolean for that.
So I think you need both the change you mentioned and the change OpenBrain mentioned together.
Can confirm change in the UI is probably useless as default value is overwritten when widget is created with actual object property value : https://github.com/FreeCAD/FreeCAD/blob ... pp#L69-L70
