[BUG] MacOS at startup crash (critical)
Re: [BUG] MacOS at startup crash (critical)
Yes I just try in English - English, same issue...
Perhaps it's an addon, or the config. Try removing both FreeCAD directories in ~/Library/Application Support/ and ~/Library/Preferences/
User on github (who isn't able to use the forum due to not getting activation email post-registration) has also encountered this issue and has figured out it has to something to do with homebrew dependency qt-webengine:
I just deleted the FreeCAD folders in ~/Library/Application Support/ and ~/Library/Preferences/
same issue....
I think it is an interesting way, I use Homebrew too, I try to find if qtwebengine is installed... not easy to know if is included inside another package.
I noticed in my command line logs that binary was searching for some resource files in my home path ~/.FreeCAD. I have copied and it works for me in MacOS Monterey.
cp /Applications/FreeCAD.app/Contents/Resources/resources/* ~/.FreeCAD
I' ve finally found the reason for this error message:
17:01:35 Qt WebEngine resources not found at /Applications/FreeCAD.app/Contents/Resources/Resources. Trying parent directory...
When I look into the application I see
with a lowercase "r".
If I rename the folder to "Resources" it works.
This affects only a small number of macOS users, since the default is to ignore case.
It would be nice to get this fixed in 0.21.
Greetings Axel
Greetings Axel
Please create a Github ticket for this.
- adrianinsaval
this should not be a problem in 0.21: https://github.com/FreeCAD/FreeCAD-Bund ... C67-L55C67
