Chamfer problem
user1234
Re: Chamfer problem
Post by user1234 »
cehjan wrote: Thu Sep 08, 2022 8:34 pm I always forget to try to apply refine. It also works if I apply Refine only to the first 3 features.
I would do it like @Shalmeneser. Not all chamfer/fillets should be on the end, it is context sensitive. And because it belongs to the base form, i would do it when the base form is finished. (Also i would do the base shape with intersections, but that is an other thing).
Greetings
user1234
Shalmeneser
Re: Chamfer problem
Post by Shalmeneser »
:idea:
(the chamfer around is heavy)
Spojnica_SHALM2.FCStd
(692.38 KiB) Downloaded 44 times
Capture du 2022-09-08 22-54-37.png (90.5 KiB) Viewed 752 times
Re: Chamfer problem
I am one of the fiew to advocate early filling. The reason is the topological naming problem: the earlier you fillet, the less features can break by parametric changes.
cehjan
Re: Chamfer problem
Post by cehjan »
Logical, but when you use commercial 3D CAD software for 20 years, then you are a little spoiled, i.e. you don't think about the software while working but about the 3D model.
