[Ongoing] Testing Toponaming in upstream FreeCAD
Smiling_user
Re: FreeCAD Contribution Process
Post by Smiling_user »
Tried to test :
in the file attached - changing parts of contour in "Sktch_A" - will cause destruction of whole body.
Trying to reapply sketch "Sktch_B" to same site of "Pad" did not work. [menu>Sketch>Map sketch to face]
OS: Ubuntu 18.04.6 LTS (KDE/plasma)
Version: 0.21.14555 (Git shallow) AppImage
Branch: development/toponaming
Hash: d2d0b7f01884bf2c8838c07f4389c9e64fc703b5
20221108-toponaming_test_PartDesign.FCStd
(41.71 KiB) Downloaded 152 times
Smiling_user
Re: [Ongoing] Testing Toponaming in upstream FreeCAD
Posted somewhere already, that in the attached file changing the contour of Sktch_A results in whole "body" destruction.
Not sure this is a bug, because there is PartDesign used between sketches, but
Toponaming improvements are built it to the core and to the Sketcher and Part workbenches.
only.
(41.71 KiB) Downloaded 169 times
if it's not for a regression from master branch testing PD is irrelevant right now, the PD portion of toponaming is not yet in the branch.
Smiling_user wrote: Tue Nov 08, 2022 2:11 pm Tried to test :
I have moved your post here. It was in the topic about the contribution process.
Smiling_user
It's OK:
Idea:
// take elements as geometry primitives( dot, line, 2D-plane inside 3D object), objects as 2D and 3D figures
1. building PD "Body" step by step = system of connected/linked - "condependant" elements and objects.
2. => thus changing previous element changes all descendants
Is it possible to add a new element to description of each element?
it is: after clicking "Close" - each element of currently built object receives index of "topo-name" in terms of general coordinates.
after making changes in some parent object - each element is reindexed for topo-name, identified according to previos topo-names and each descendant
receives binding to reidentified element.
So the new is:
1. identify created elements in terms of general coordinates
2. re-identify created elements after object rebuilt
3. reattach descendants to re-identified elements
ngocminhdao88
Post by ngocminhdao88 »
I got this error when opening my file (see attachment). FreeCAD is still working though.
14:01:07  <Exception> StringHasher.cpp(542): Invalid string table
14:01:07  <Base> Reader.cpp(749): Reading failed from embedded file: StringHasher.Table.txt
FreeCAD info:
Version: 0.20.29382 +85 (Git)
Hash: 51621458b503a7759496e389b1f4a4f02fee8289
  * Assembly4 0.12.4
  * CurvedShapes 1.0.4
  * Curves 0.6.4
  * fasteners 0.4.25
  * freecad_metal_workbench 0.0.1
  * lattice2 1.0.0
  * PieMenu 1.2.4
  * QuickMeasure 2022.10.28
  * sheetmetal 0.2.59
cooling_air_splitter.FCStd
(299.31 KiB) Downloaded 162 times
obelisk79
Post by obelisk79 »
Just following up on this effort and Happy New Year to all!
It seems like progress was quite steady and has slowed down significantly regarding the wait for the final PR integrating TNP mitigation into Part Design for testing. Is there any way those of us interested in testing further can be given an expectation when this branch will be sync'd to master and the final integration merged?
I understand December tends to be a busy time of year full of distractions for those involved, I just hope the enthusiasm behind this effort doesn't die-off before it can be integrated fully.
@realthunder @uwestoehr
jerome992
Post by jerome992 »
I have posted a bug in Sketcher here: https://forum.freecadweb.org/viewtopic. ... 88#p650988
filippor
Post by filippor »
I think this branch Is diverging from master. Why don't periodically merge from master?
lamikr
Post by lamikr »
filippor wrote: Mon Jan 30, 2023 8:24 pm I think this branch Is diverging from master. Why don't periodically merge from master?
It's has been done for a while now. You cam track the progress on
https://github.com/FreeCAD/FreeCAD/issues/8432
