[Ongoing] Testing Toponaming in upstream FreeCAD
mfro
Re: [Ongoing] Testing Toponaming in upstream FreeCAD
Post by mfro »
wsteffe wrote: Sat Sep 17, 2022 8:22 am Regarding the L-Profile constraint, I think that now, after merging of toponaming3 which provides support for sketch, the problem is solved also in branch development/toponaming.
Tried that as well yesterday and can confirm it's fine now.
Cheers,
Markus
wsteffe
Post by wsteffe »
adrianinsaval wrote: Thu Sep 15, 2022 8:55 pm part extrude with taper angle works incorrectly (nested profiles are filled)
I have just checked that this bug persists after merging of toponaming3. I have also seen that it affects also the current RT branch LinkDaily. So I do not expect it can be fixed in the next PR (toponaming4).
It seems that this bug was actually introduced by toponaming related PRs. The only other possibility is that it was preexisting but fixed in a recent Master Commit not yet included in currrent development/toponaming and in RT/LinkDaily.
I doubt that, it was working fine in 0.20 and later IIRC
wsteffe
Post by wsteffe »
adrianinsaval wrote: Sun Sep 18, 2022 3:26 pm I doubt that
But it is also quite strange that this kind of bug can be caused by the topo-naming stuff: It works fine with angle=0 while it fails with angle>0. The topology is the same in both cases.
the extrusion algorithm is not the same for both cases, for angle=0 it directly uses a extrusion function from occt, when there is a taper angle it has to use different occt functions, I suspect there was some conflict there, realthunder had his own extrusion taper implementation, perhaps some of that got mixed in and causes trouble.
realthunder
Post by realthunder »
PR submitted for the taper angle problem. The topo naming enabled algorithm is what originally implemented before the upstream version. I choose to retain it because it problem extra function like independent outer and inner tapper angles (for holes). The PR fixed the backward compatibility by adding a new property AutoTaperInnerAngle defaults to True, which will auto fill the inner taper angle as the negative of outer one which is the same behavior as upstream master.
lamikr
Post by lamikr »
I did a git pull but did not see the fix in development/totonaming branch.
@lamikr hasn't been merged yet. ;)
obelisk79
Post by obelisk79 »
Has the 4th PR, implementing TNP into Part Design, been submitted yet? I was checking github and don't see it anywhere, however admittedly I'm far from an expert at navigating github.
Is there any ETA on when this may be getting merged?
Thanks to all involved, I realize that incorporating this code is a major undertaking and I am not attempting to rush the process.
These are the toponaming PRs that have been merged:
The pending toponaming PR in queue is https://github.com/FreeCAD/FreeCAD/pull/7534
Edit: Now all toponaming related PRs use the 'Toponaming' label.
