FreeCAD Nodes (renamed from fc_nodes)
drmacro
Re: FreeCAD Nodes (renamed from fc_nodes)
Post by drmacro »
j8sr0230 wrote: Wed Nov 30, 2022 9:30 pm ...
Used the File>Save menu to save them.
But, they saved with no extension and the File>Open doesn't see them.
Thanks for your report!. Actually, the files should be automatically saved as JSON files. Can you open them when you append *.json to your files?
Now have 0.1.24 installed.
Saved node files still don't load.
Edit: One issue appears to be that if there is the node file includes a CViewer node and there is no document in FreeCAD the opening of the node file fails. But, this does not correct the open error in other cases.
drmacro
Post by drmacro »
In the process of trying to figure out what Im doing wrong saving the node json files I reproduced one of the examples shown on github.
I think this duplicates https://github.com/j8sr0230/Nodes/blob/ ... _shape.gif
But, when I move the slider I get this:
newalignshapes-6.json.zip
(21.65 KiB) Downloaded 44 times
drmacro
Post by drmacro »
After Nodes update with Addonmanager, none of my json files will load. :(
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 397, in deserialize
    new_node = self.getNodeClassFromData(node_data)(self)
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 360, in getNodeClassFromData
    return Node if self.node_class_selector is None else self.node_class_selector(data)
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_sub_window.py", line 50, in get_node_class_from_data
    return NodesStore.get_class_from_opcode(data['op_code'])
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_conf.py", line 44, in get_class_from_opcode
    raise OpCodeNotRegistered("OpCode '%d' is not registered" % op_code)
11:13:11  TypeError: %d format: a number is required, not str
11:13:11  Traceback (most recent call last):
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 327, in loadFromFile
    self.deserialize(data)
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 435, in deserialize
    new_edge = Edge(self).deserialize(edge_data, hashmap, restore_id, *args, **kwargs)
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_edge.py", line 301, in deserialize
    self.end_socket = hashmap[data['end']]
11:13:11  KeyError: 139971523285200
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_default_node.py", line 297, in eval
    return self.eval_primer()[index]
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_default_node.py", line 338, in eval_primer
    self.markDescendantsDirty()
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_node.py", line 345, in markDescendantsDirty
    for other_node in self.getChildrenNodes():
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_node.py", line 414, in getChildrenNodes
    other_node = edge.getOtherSocket(self.outputs[ix]).node
11:13:11  AttributeError: 'NoneType' object has no attribute 'node'
11:13:11
During handling of the above exception, another exception occurred:
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_window.py", line 137, in onFileOpen
    if nodeeditor.fileLoad(file_name):
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_sub_window.py", line 63, in fileLoad
    self.do_eval_outputs()
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_sub_window.py", line 56, in do_eval_outputs
    node.eval()
11:13:11    File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_default_node.py", line 302, in eval
11:13:11
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.0.31238 (Git)
Hash: 6f0afb4d0b8b7a901a8b5b54e07c25e36e840548
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
  * parts_library
  * kicadStepUpMod 10.16.5
  * Manipulator 1.4.9
  * PrefExtras
  * QuickMeasure 2022.10.28
  * MyDefaults 2022.9.15
  * ZolkoBase 0.0.1
  * DynamicData 2.46.0
  * fasteners 0.4.25
  * Nodes 0.1.26
  * MacMechX 2022.9.15
  * ExtremeProDark 2.6.4
  * fcgear 1.0.0
  * plugins
  * Pyramids-and-Polyhedrons
  * Defeaturing 1.2.0
  * Assembly4 0.12.4
  * BaseTest 0.0.1
  * OpticsWorkbench 1.0.9
  * workfeature-macro
  * sheetmetal 0.2.59
  * A2plus 0.4.60f
  * CurvedShapes 1.0.4
  * BasicMech 0.0.1
  * Dracula 0.0.2
  * Curves 0.6.4
  * workfeature
  * lattice2 1.0.0
j8sr0230
Post by j8sr0230 »
drmacro wrote: Fri Dec 02, 2022 3:47 pm In the process of trying to figure out what Im doing wrong saving the node json files I reproduced one of the examples shown on github.
Hello, I have reworked the Align node again and made it a bit more user friendly. The Align node now has a pivot socket that allows you to easily define the pivot point of the rotation. Alternatively, you can use the new Dir(ection) socket of the Box node, with which you could directly align the generated Box instances to the sphere surface (see attachment).
Node graph
Node graph
Result
Result
Codelink on GitHub: https://github.com/j8sr0230/codelink
Codelink on PiPy: https://pypi.org/project/codelink/
FreeCAD Nodes Workbench on GitHub: https://github.com/j8sr0230/Nodes
j8sr0230
Post by j8sr0230 »
drmacro wrote: Tue Dec 06, 2022 4:18 pm After Nodes update with Addonmanager, none of my json files will load. :(
Thanks for your feedback. I am really sorry about that, but it is not a bug. My latest update brings significant improvement regarding the Array Broadcastig API of the node editor. Unfortunately I had to adapt many nodes for this purpose. Whenever the node interface (e.g. sockets) has changed, a preheat compatibility is not given... However, your data is not lost! I could send you an image of the Workbench preversion, which you then only have to copy into your FreeCAD user directory, to run the old node editor. This way you could create snapshots of your node graphs. Alternatively, you could also fork the previous version from my repository... Sorry for the circumstances! By the way, does the saving and loading of graphs work for you now?
drmacro
Post by drmacro »
j8sr0230 wrote: Tue Dec 06, 2022 6:24 pm
I can proceed with the new. I have nothing that extensive.
It would be nice if the example node graphs could be available though rather than having to create them from a picture... ;)
I tried to read your code to see if I could find issues, but, with no comments...not much help.
It did for like two days...until I did the Addon manager update. :lol:
j8sr0230
Post by j8sr0230 »
drmacro wrote: Fri Dec 02, 2022 2:13 pm
You got that right! The CViewer node needs an open FreeCAD document to render into. I'll be looking into this soon. Probably a new document should be created when loading a node graph, if there is none open yet. How do you see this? Unfortunately, I have not been able to reproduce your save and load problems yet. Is the error still current?
drmacro
Post by drmacro »
j8sr0230 wrote: Tue Dec 06, 2022 6:36 pm ...
Creating a new document if none exists would probably be good. Or maybe offering it to the user...they may not want nodes popping up their existing work.
I currently have 0.1.26 and R/W appears ok.
j8sr0230
Post by j8sr0230 »
drmacro wrote: Tue Dec 06, 2022 6:34 pm It did for like two days...until I did the Addon manager update. :lol:
Cool, then I can close the issue!
j8sr0230
Post by j8sr0230 »
Hi Friends,
the CrvToFace node now implements the FaceMakerBullseye class for boundary surface capabilities. The example shows a node setup that generates either 9 circular faces or 5 boundary surfaces, depending on the data structure passed.
Boundary surface
Boundary surface
