FreeCAD Nodes (renamed from fc_nodes)
Re: FreeCAD Nodes (renamed from fc_nodes)
Here's another great combined application of the new nodes, using a slider to move an object along a trajectory and align it normal to the surface.
Codelink on GitHub: https://github.com/j8sr0230/codelink
Codelink on PiPy: https://pypi.org/project/codelink/
FreeCAD Nodes Workbench on GitHub: https://github.com/j8sr0230/Nodes
This is one of my favorite threads ATM...it's magic each time it's updated
I created a couple node diagrams yesterday.
Used the File>Save menu to save them.
But, they saved with no extension and the File>Open doesn't see them.
I tried a couple extensions (grph, gph, ...) but, still not found.
The files I named are there, just without any extension.
- MisterMaker
I got a json extension. Maybe we can dump it in the freecad file and add a export/import node function?
Thanks for your report!. Actually, the files should be automatically saved as JSON files. Can you open them when you append *.json to your files?drmacro wrote: ↑Wed Nov 30, 2022 8:08 pm I created a couple node diagrams yesterday.
Thanks for the idea. I know that microelly2 has saved the node graphs of his PyFlow node editor version in the FreeCAD file. I will check this and take a look at the *.FCStd format.MisterMaker wrote: ↑Wed Nov 30, 2022 8:34 pm I got a json extension. Maybe we can dump it in the freecad file and add a export/import node function?
Thanks for the flowers! I do my best to continue to meet the high expectations As slowly but surely more and more users discover FreeCAD Nodes, I should probably shift my priorities from node development towards project organization, junior staff recruitment, quality assurance and node documentation. Am curious where the journey goes
Note below that Help>About shows Nodes 0.1.23, but Addon manager says 0.0.19, up to date.
- adding the .json extension allows the File>Open dialog to see the file.
- the File>Save dialog does no add .json
10:36:17 Traceback (most recent call last):
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 397, in deserialize
new_node = self.getNodeClassFromData(node_data)(self)
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./nodes/viz/viz_compound_viewer.py", line 46, in __init__
self.fc_obj = App.ActiveDocument.addObject("Part::Feature", "CViewer")
10:36:17 AttributeError: 'NoneType' object has no attribute 'addObject'
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 360, in getNodeClassFromData
return Node if self.node_class_selector is None else self.node_class_selector(data)
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_sub_window.py", line 50, in get_node_class_from_data
return NodesStore.get_class_from_opcode(data['op_code'])
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_conf.py", line 44, in get_class_from_opcode
raise OpCodeNotRegistered("OpCode '%d' is not registered" % op_code)
10:36:17 TypeError: %d format: a number is required, not str
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 327, in loadFromFile
self.deserialize(data)
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_scene.py", line 435, in deserialize
new_edge = Edge(self).deserialize(edge_data, hashmap, restore_id, *args, **kwargs)
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_edge.py", line 301, in deserialize
self.end_socket = hashmap[data['end']]
10:36:17 KeyError: 140059223251648
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_default_node.py", line 297, in eval
return self.eval_primer()[index]
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_default_node.py", line 338, in eval_primer
self.markDescendantsDirty()
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_node.py", line 345, in markDescendantsDirty
for other_node in self.getChildrenNodes():
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./lib/nodeeditor/node_node.py", line 414, in getChildrenNodes
other_node = edge.getOtherSocket(self.outputs[ix]).node
10:36:17 AttributeError: 'NoneType' object has no attribute 'node'
10:36:17
During handling of the above exception, another exception occurred:
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_window.py", line 137, in onFileOpen
if nodeeditor.fileLoad(file_name):
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_sub_window.py", line 63, in fileLoad
self.do_eval_outputs()
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_sub_window.py", line 56, in do_eval_outputs
node.eval()
10:36:17 File "/home/mac/.local/share/FreeCAD/Mod/Nodes/./core/nodes_default_node.py", line 302, in eval
10:36:17
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.31162 (Git)
Hash: cc8a30929abd67a77684a855f2741d9ff91d993e
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
* parts_library
* kicadStepUpMod 10.16.5
* Manipulator 1.4.9
* PrefExtras
* QuickMeasure 2022.10.28
* MyDefaults 2022.9.15
* ZolkoBase 0.0.1
* DynamicData 2.46.0
* fasteners 0.4.24
* Nodes 0.1.23
* MacMechX 2022.9.15
* ExtremeProDark 2.6.4
* fcgear 1.0.0
* plugins
* Pyramids-and-Polyhedrons
* Defeaturing 1.2.0
* Assembly4 0.12.4
* BaseTest 0.0.1
* OpticsWorkbench 1.0.9
* workfeature-macro
* sheetmetal 0.2.59
* A2plus 0.4.60e
* CurvedShapes 1.0.4
* BasicMech 0.0.1
* Dracula 0.0.2
* Curves 0.6.4
* workfeature
* lattice2 1.0.0
- BuildArray_json.zip
- (24.69 KiB) Downloaded 46 times
I also used a FC object to store a file, see https://github.com/FlachyJoe/FCPDWorkbe ... ude.py#L93
NB : file is open in an external app, it will be easier in your case.
