the upper deviation should be aligned to left not to right compared to lower one (see attachment)edi wrote: ↑Fri Sep 23, 2022 1:19 pm Find attached the first version of a macro creating shaft/hole tolerances using ISO 286.
The macro uses some of the preferentially recommended fields, shown in tables 12 and 13 of ISO 286, https://docplayer.org/55190189-Deutsche ... 286-1.html
TaskHoleShaftFitISO286.ui
HoleShaftFitISO286.FCMacro
Installation: Copy the two files TaskHoleShaftFitISO286.ui and HoleShaftFitISO286.FCMacro into your macros holding directory.
Workflow:
- open a TechDraw drawing.
- select one distance dimensioning (horizontal, vertical or oblique) or one circle diameter dimensioning.
- start the macro. A panel opens in the Combo View.
- select shaft fit / hole fit to show whether your dimensioning refers to a shaft or a hole.
- select the desired ISO 286 fit field using the combo box. The partner field and the fit type (loose, snug, press) is shown.
- click the OK button.
The label of the selected field and the calculated tolerance values are shown in the drawing.
Please test the macro and give me feedback.
[Feature Request]: ISO shaft/hole tolerances for dimensions
Re: [Feature Request]: ISO shaft/hole tolerances for dimensions
- Tolerance.jpg (174.52 KiB) Viewed 1533 times
@wandererfan
this macro should be implemented as a tool in TD, what do you think?
- wandererfan
I will try to implement this this tool, but I will need some time.
To everybody: Please checkout the several combinations, and give me feedback if there are returned improper numbers.
Has anybody a proposal for an icon to represent the shaft/hole tolerances tool ?
Please post here as 64x64 pixel svg. No characters or numbers allowed in the icon!
My proposal for an icon for engineering fit:
@NewJoker
You killingjoke...
I am curious how edi wants to get this solved, so that an unambiguous logo comes out. LOL
You killingjoke...
- wandererfan
"This one is too big. And this one is too small. But this one is just right". https://en.wikipedia.org/wiki/Goldiloc ... hree_Bears
If I had any artistic skill, I would make an icon of a little girl and three bears to go with dolly the sheep.
My icon proposal:
I plan to place the icon in the Annotation group, next to SurfaceFinishSymbols.
