Path Workbench Code restructuring - heads up
GeneFC
Re: Path Workbench Code restructuring - heads up
Post by GeneFC »
Russ4262 wrote: Sat Mar 18, 2023 11:49 pm
I will not be able to update the script or details later since I am unable to access locked threads. A forum admin will have to do so.
Sorry. Guess that is a bad idea.
:oops: :oops: :oops: :oops: :oops:
Gene
Russ4262 wrote: Sat Mar 18, 2023 11:49 pm I will not be able to update the script or details later since I am unable to access locked threads. A forum admin will have to do so.
I will do some tests tomorrow.
Result of my research and tests is this:
Admins can lock and unlock topics
Nobody can reply to a locked topic. This includes admins
Admins can edit a post in a locked topic
Normal users cannot edit their own posts in a locked topic.
So I propose:
- Russ creates a new topic asking that nobody should reply
- a moderator will pin and lock this topic
- I will fill the topic as described above.
This will enable us in the future to update the topic by a moderator or to unlock it so that Russ can edit it himself. I can create the initial version, but I can't create the topic in Russ' name. I can, if you so wish, of course create the topic myself.
