Path Workbench Code restructuring - heads up
GeneFC
Re: Path Workbench Code restructuring - heads up
Post by GeneFC »
chrisb wrote: Tue Sep 06, 2022 2:44 pm Until now Path workbench was written in Python. Is this still so? Then I could replace the whole Mod/Path directory to get the new stuff?
I actually tried that first. I simply replaced everything in Mod/Path. It did not work because there are some hooks back into the FreeCAD core that need to be recompiled.
Most of the Path WB source is python, but there are some important C++ portions as well.
I don't know if a more intelligent approach would work.
Gene
mlampert
Post by mlampert »
GeneFC wrote: Tue Sep 06, 2022 2:51 pm
The issue was that I could not move the C++ and the Python backed classes into a single namespace without moving the C++ somewhere else first. So unfortunately a recompile is required.
For nerds:
The C++ classes now publish their python bindings in the module "PathApp". The "Path" namespace is now a pure python module which, upon it being imported, imports everything from the "PathApp" module which puts the C++ objects back where they were.
sliptonic
Post by sliptonic »
I found a couple small bugs and mlampert fixed them immediately. Gene found some issues with surface and those were fixed too. Otherwise this has not gotten much comment. So I'm assuming it's all good.
I'll be merging this as soon as mlampert gives me the final go-ahead.
If anyone has concerns, speak now or forever hold your peace.
LarryWoestman
Post by LarryWoestman »
So far I have found a couple of trivial bugs that were easily fixed.
Go for it!
mlampert
Post by mlampert »
PR is merged - once it makes it through the pipeline the code structure hopefully makes more sense.
bmsaus4ax
Post by bmsaus4ax »
Updated FreeCAD via the in program updater and am assuming this includes the recent merge of the code restructuring.
On opening my most recent project the result is as referenced in Gene's earlier post.
GeneFC wrote: Tue Sep 06, 2022 1:16 pm As pointed out above the change is rather dramatic. No sense in adding to master until it is quite thoroughly debugged at the PR level.
I have taken a first look. In general it seems to work pretty well for new Path WB jobs, but completely fails to handle existing jobs. They are not even recognized. I do not know if that can be fixed in any way or if some sort of converter might be possible, but that is why the testing period on the PR exists.
Gene
The directory tree structure has exploded, most branch links are broken although some Operations still have some members.
Access to items in Gui is mostly non existent , but using Python Console via Python dot scope shows contents still valid.
ReportView on initial opening of file:
07:45:09  Recent macros : keyboard shortcut 1 disabled because conflicting with Std_ViewFront
07:45:09  Recent macros : keyboard shortcut 2 disabled because conflicting with Std_ViewTop
07:45:09  Recent macros : keyboard shortcut 3 disabled because conflicting with Std_ViewRight
07:45:15  Traceback (most recent call last):
  File "/tmp/.mount_FreeCA0EhgPR/usr/lib/python3.10/site-packages/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathJob'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSetupSheet'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathStock'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolBit'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolController'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathCustom'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathDressupHoldingTags'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathDrilling'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathPocketShape'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSurface'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathProfile'
07:45:16  Traceback (most recent call last):
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathJobGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSetupSheetGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathIconViewProvider'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolBitGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolControllerGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathOpGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathDressupTagGui'
This Version:
OS: Ubuntu 20.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.30669 (Git) AppImage
Hash: 48b4eed55c05452d2cbabb9a8ba4c75e1a54481e
  * fcgear 1.0.0
  * Curves 0.4.4
  * Lithophane
  * CurvedShapes 1.0.3
Version in which file last modified and valid:
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
  * fcgear 1.0.0
  * Curves 0.4.4
  * Lithophane
mlampert
Post by mlampert »
As mentioned earlier, the refactor breaks all existing Jobs. You'll have to delete all Jobs, their operations and associated objects and create the anew.
bmsaus4ax
Post by bmsaus4ax »
mlampert wrote: Tue Oct 18, 2022 1:16 am As mentioned earlier, the refactor breaks all existing Jobs. You'll have to delete all Jobs, their operations and associated objects and create the anew.
Or retain working copy of a pre-change AppImage. (My intention)
This covers historical projects for those of us with an archive of jobs.
Please post link to the previous mention of this. TIA!
