2D airfoil simulation
Moderator: oliveroxtoby
Re: 2D airfoil simulation
now I'm trying to do a segmented airfoil:
but meshing ends in error:
--> FOAM FATAL ERROR: (openfoam-2206)
Plane normal not aligned with the coordinate system
    pn = (0.828017607417294 -0.430746258010021 0.35894916494861)
    From Foam::direction Foam::twoDPointCorrector::normalDir() const
    in file twoDPointCorrector/twoDPointCorrector.C at line 240.
FOAM aborting
20:53:23  #0  Foam::error::printStack(Foam::Ostream&) at ??:?
20:53:23  #1  Foam::error::simpleExit(int, bool) at ??:?
20:53:23  #2  Foam::twoDPointCorrector::normalDir() const at ??:?
#3  ? in /opt/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/flattenMesh
20:53:23  #4  ? in /usr/lib/libc.so.6
20:53:23  #5  __libc_start_main in /usr/lib/libc.so.6
#6  ? in /opt/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/flattenMesh
20:53:23  ./Allmesh: line 18: 168646 Aborted                 (core dumped) "$@" > >(tee -a log."$sol") 2> >(tee -a log."$sol" >&2)
20:53:29  Traceback (most recent call last):
20:53:35    File "/home/adrian/.local/share/FreeCAD/Mod/CfdOF/./CfdOF/Mesh/TaskPanelCfdMesh.py", line 382, in openParaview
20:53:35      self.open_paraview = CfdTools.startParaview(case_path, script_name, self.consoleMessage)
20:53:35    File "/home/adrian/.local/share/FreeCAD/Mod/CfdOF/./CfdOF/CfdTools.py", line 1227, in startParaview
20:53:35      CfdConsoleProcess.removeAppimageEnvironment(env)
20:53:35  AttributeError: type object 'CfdConsoleProcess' has no attribute 'removeAppimageEnvironment'
If I open it in paraview anyways it looks horrible:
I think I need to set very low mesh sizes for it to succeed but I don't want the entirety of my domain to have very fine mesh, is there a way to make a volume refinement on the airfoil region before doing the cut?
segmented-airfoil-cfd.FCStd
(83.15 KiB) Downloaded 66 times
thschrader
Post by thschrader »
Used 2 wings as a start.
chord-length upper wing 400 mm
gap between wings 8 mm.
mesh:
cfmesh, 3 volume refinement stages, 1 surface refinement, 10 boundary-layers.
meshing time approx 25 min.
Fluid air, rho=1,2 kg/m^3, inlet=5 m/s, 0 Pa, 5% turbulence, k-omega model
SimpleFoam converges after 800 iterations, at Res=10^-3, runtime 35 min.
Result:
lift upper wing: 5,4 N/m
lift lower wing: -0,08 N/m (yes, minus lift!)
Would be better to use the upper wing alone...
segmentedAirfoil.FCStd
(741.58 KiB) Downloaded 73 times
techGuy
Post by techGuy »
Why do I have these black areas around the airfoil in my Paraview output ?
Is this a meshing problem or a solver problem ?
SegmentedAirfoil U.png (281.1 KiB) Viewed 1235 times
SegmentedAirfoil p.png (145.48 KiB) Viewed 1235 times
what black areas? you mean the faces of the extrusion? try enabling parallel projection view in paraview to not see those.
techGuy
Post by techGuy »
Much better !
techGuy
Post by techGuy »
Much better !
techGuy
Post by techGuy »
thschrader wrote: Sun Sep 11, 2022 10:07 am mesh:
What machine are you using ?
Result:
That is because there is no air flow through the gap and the upper flow is detached by the time it reaches the lower wing.
SegmentedAirfoil-detatched flow.png (103.99 KiB) Viewed 1173 times
herbk
Post by herbk »
thschrader wrote: Sun Sep 11, 2022 10:07 am Result:
Try it... ;)
I would say: without the lower wing the upper wing produces distinctly less lift.
Gruß Herbert
thschrader
techGuy wrote: Mon Mar 20, 2023 8:40 pm What machine are you using ?
The sim above was done on a HP-Laptop with intel i5 CPU, 35 min runtime.
I rerun the file on my new Laptop with Intel i7, 2x CPU active.
Now meshing in 9 min, runtime sim 14 min.
thschrader
herbk wrote: Tue Mar 21, 2023 7:33 am Try it... ;)
Moin Herbert,
you are right.
Both wings: 81,7+3,3=85 N/m total lift
Upper wing alone: 46 N/m lift :o
15 m/s inlet speed, 4 deg AoA
Values in N/m are "computed-lift/mesh-thickness"
You must run the sim to 10E-5 residual cut-off before lift force stabilizes.
big_wing_alone.FCStd
(422.05 KiB) Downloaded 49 times
