FreeCAD 0.21 hangs when opening spreadsheet on windows
Reproducible even with clean config, tested on two separate systems, steps:
-open freecad
-new document
-switch to spreadsheet workbench
-create new spreadsheet, the spreadsheet opens automatically
-FreeCAD hangs for some time and eventually is responsive again
-close spreadsheet
-FreeCAD hangs and is responsive again after some time
-reopening the spreadsheet FreeCAD hangs again
Version: 0.21.30121 (Git)
Hash: 9c929897ac46f2309e2bf34b7106f49fcb737a1d
Re: FreeCAD 0.21 hangs when opening spreadsheet on windows
@looo issue seems to be with conda packaging, I can reproduce with this version of 0.20.1:
Version: 0.20.1.29410 (Git)
and same with py3.8 version:
Version: 0.21.30143 (Git)
Hash: a72bf218f9917df37e811d7e73a36333282028f5
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
but not with this (installer version):
Branch: releases/FreeCAD-0-20
looo
Post by looo »
@adrianinsaval
Is this also reproducible with the weekly builds?
can't reproduce with from conda:
OS: macOS 12.4
Version: 0.21.30138 (Git)
Hash: f5c5eec3bbe6cf1499d34d292d154d48e6285c0f
Locale: German/Austria (de_AT)
  * ThreadProfile 1.81.0
  * PieMenu
  * fasteners 0.3.44
  * Assembly4 0.12.0
  * Assembly3 0.11.3
arm64 / and rosetta.
also no problems with linux:
OS: Ubuntu 22.04 LTS (ubuntu:GNOME/ubuntu)
  * Assembly3 0.11.3
also with this version I can't reproduce (but this is still only conda and not the bundle)
  * Plot
and also no issue with the bundle:
  * Plot
I created a new document, switched to spreadsheet workbench, created a new spreadsheet (was created instantly), closed it (closed normally), opened it again (again no issue). Did I do something wrong?
looo wrote: Tue Aug 23, 2022 8:43 am @adrianinsaval
Yes, if you see my first post that's where I first noticed this issue
looo wrote: Tue Aug 23, 2022 8:43 am I created a new document, switched to spreadsheet workbench, created a new spreadsheet (was created instantly), closed it (closed normally), opened it again (again no issue). Did I do something wrong?
No, that's exactly what I do but FreeCAD hangs for me, this happens on two different computers so it doesn't look like being specific to my machine.
GeneFC
Post by GeneFC »
I tried on two different computers, and I saw no delays. Exactly the same source file just downloaded a few minutes ago.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
  * FeedsAndSpeeds 0.4.0
  * FeedsAndSpeeds-master.zip
  * Help 1.0.3
  * offline-documentation
OS: Windows 10 Version 2009 (Actually Windows 11 21H2 22000.856)
  * Help 1.0.3
However, in both cases, as well as my previous experience, the spreadsheet did not open automatically. I needed to double-click the Spreadsheet entry in the main tree to get the new spreadsheet window.
Gene
I can reproduce in two different windows 10 machines
Locale: C/Default (C) [ OS: Spanish/Paraguay (es_PY) ]
  * ArchTextures
  * CurvedShapes 1.0.4
  * Curves 0.5.6
  * Defeaturing
  * fasteners 0.3.38
  * FCsuWB-dev
  * Glass
  * SelectorToolbar
  * Silk 1.0.0
even with clean config, even removing the registry entry for FreeCAD window state, funny enough in one machine the spreadsheet opens automatically when I create one, in the other I have to double click to open. What could be the common factor? Why is it only affecting me?
In both computers the 0.20.1 version from the installer works fine.
Off-topic but how did you convince python 3.10 to run on your win7 machine? Or have they changed something that brought compatibility back? Or is it because it's from conda?
GeneFC
Post by GeneFC »
adrianinsaval wrote: Tue Aug 23, 2022 2:55 pm Off-topic but how did you convince python 3.10 to run on your win7 machine?
I added the missing file that was floating around here a couple of weeks ago. I was rather amazed that it worked. I had (mis)understood that there were a number of new API calls in Python 3.9+ that were not part of Windows 7. It appears there were not many, and the single added file works.
Who knows for how long?
Gene
Ah right! I forgot about that post (since I didn't need it) but I've seen it too.
I could not reproduce on the appimage on linux, on windows it still hangs but I noticed I need to click on a spreadsheet cell after activating the spreadsheet to make it hang. Is really nobody else having this issue? How can I find out what is going wrong here?
Shalmeneser
Post by Shalmeneser »
adrianinsaval wrote: Tue Aug 30, 2022 12:37 pm I could not reproduce on the appimage on linux, on windows it still hangs but I noticed I need to click on a spreadsheet cell after activating the spreadsheet to make it hang. Is really nobody else having this issue? How can I find out what is going wrong here?
I have the same problem with 0.21 : clicking on a cell will hang FC (I close FC, don't know if it wakes up later).
OS: Windows 10 Version 1809
Version: 0.21.30058 (Git)
Hash: cb96332a64db8ae855ca700212eebb0f5151230a
Locale: French/France (fr_FR)
  * fasteners 0.4.3
  * fcgear 1.0.0
  * Manipulator 1.4.9
  * sheetmetal 0.2.56
