[UX] FreeCAD getting started wizard
Zolko
Re: [UX] FreeCAD getting started wizard
Post by Zolko »
MisterMaker wrote: Sat Nov 05, 2022 8:54 pm And I ended up with 3 almost empty pages, and so I put it all into one page and so ended up with this:
I really think that this is great and should be included into FreeCAD as a first-start welcome screen.
Choice of language, units OK, but I'd skip the look and feel part, because a new user can't know how big or small icons will ultimately look, or what a Classical theme is, or what Orbit-style to use. We have Preference Packs with which the user can fine-tune his setup. The intent of use is also a good addition.
As for the buttons, I'd rather call them "Start" and "Ignore", and remove "Back" (back to what ?)
MisterMaker
Post by MisterMaker »
This is btw the next and last page, it is a copy from this project with extra donating sentence.
I could not move the cancel to the left only move one place to the left.
MisterMaker
The bottom part is part of the QT_wizard class and isn't as versatile as normal QT menu's.
https://doc.qt.io/qt-5/qwizard.html
If you btw want to have a good laugh:
https://twitter.com/MisterMakerNL_/stat ... 60/photo/1
Not posting it here since it has the (we do not speak off) logo.
sliptonic
Post by sliptonic »
sliptonic wrote: Sat Nov 05, 2022 9:47 pm This is a cool initiative and in line with an old outstanding issue.
Could someone please take the time to update the issue so it reflects the current work and make it easier to merge a solution when one is ready.
Specifically, the issue should accurately describe the problem we're trying to solve and the minimum acceptable solution criteria.
Please make the issue link to this discussion and, to the whatever degree is appropriate, continue the discussion in the issue.
We are trying to move to a more effective and fair development process. That starts with accurately and narrowly defining the issues.
I'm strongly encouraging you all to move the discussion of this feature to the appropriate issue.
MisterMaker
Been learning QT for this evening finally beginning to understand stuff.
So this time everything you see is coded.
Haavard
Post by Haavard »
MisterMaker wrote: Sun Feb 26, 2023 9:40 pm Been learning QT for this evening finally beginning to understand stuff.
Looking great, good job!
Hologram
Post by Hologram »
Looking good! Only thing you could add is the specific mouse + modifier button listing (MMB pan, RMB rotate for Scheme A). I think you already know there'll be more options that are not listed in the mock-up (I use Revit navigation).
Also, don't forget to change the 'annuleren', 'volgende', etc. buttons. Even though everyone should just learn Dutch. 😉
MisterMaker
@Hologram The dutch is some magic auto language stuff in QTWizard. Should probably change when setting language.
No clue atm how that works.
chennes
Post by chennes »
Prepping for translation is easy, don't worry about it right now. Drop this over on that GitHub issue and let's start deciding whether this is the right path forward, then get it to a PR.
Chris Hennes
Pioneer Library System
suggest adding panel layout selection too
