[Sketcher] Arrow heads disappear on hiding the grid
FBXL5
Re: [Sketcher] Arrow heads disappear on hiding the grid
Post by FBXL5 »
Roy_043 wrote: Mon Apr 17, 2023 7:32 pm Do you still get this in more recent dev versions?
Yes. With this weekly build
OS: macOS 10.16
Version: 0.21.0.32532 (Git)
Hash: 20e44eba50e1365b9e7bb9c5c244afe96a627a28
Locale: C/Default (C)
  * freecad.gears 1.0.0
  * fcgear 1.0.0
  * Render 2023.2.2
  * Curves.backup1662374221.0929039
  * fasteners 0.4.55
  * sheetmetal 0.2.63
  * Help 1.0.3
  * Curves 0.6.8
  * Assembly3 0.11.4
the arrows behave like this (have a look at the dimensions as well):
I skipped the back views for One pass since they match the correct front views.
Roy_043 wrote: Mon Apr 17, 2023 7:32 pm I saw a mention of this on the Sketcher_Preferences page.
The description according to the Transparent objects setting is still valid, but it seems to be independent of the grid now.
@chrisb and @adrianinsaval can you still reproduce this behaviour?
With adrianinsaval's Linux system and Chris' and my 3 macOS systems it seems to relate to unix-based OSs.
"There is another preference that has an influence on sketches." should better read "... that may have an influence..."
FBXL5 wrote: Tue Apr 18, 2023 8:13 am The description according to the Transparent objects setting is still valid, but it seems to be independent of the grid now.
Yes and even worse: If I have grid enabled plus One pass everything is ok. If I then switch the preferences while in Sketcher, the arrows disappear even with grid enabled:
Snip macro screenshot-7e7b50.png (3.21 KiB) Viewed 2526 times
I have the same version as you:
OS: macOS High Sierra (10.13)
  * fasteners 0.4.15
  * sheetmetal 0.2.63
  * Curves 0.6.8
Roy_043
Post by Roy_043 »
Thanks.
I can't reproduce on Linux either (same computer). So perhaps it is hardware related.
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.20.2.29177 +426 (Git) Snap 517
Branch: tag: 0.20.2
Python 3.8.10, Qt 5.15.5, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
FBXL5
Post by FBXL5 »
Roy_043 wrote: Tue Apr 18, 2023 10:05 am I can't reproduce on Linux either (same computer). So perhaps it is hardware related.
What should cause hardware to display arrow heads from one direction but not from the other?
If it is related to depth or visibility calculation I would rather think it is software causing calculation errors than hardware.
Are there known issues related to mac hardware?
Especially
- 2012 MacBook Pro i7 with NVIDIA/Intel graphic card
- 2015 iMac i7 with AMD graphic card
I'm still curious if adrianinsaval's linux machine still reproduces this imperfection.
Shalmeneser
Post by Shalmeneser »
OpenGL ?
Shalmeneser wrote: Tue Apr 18, 2023 10:06 pmOpenGL ?
I don't think so. I tried with SoftwareOpenGL and it's the same.
FBXL5
Post by FBXL5 »
Neither OpenGL setting has an impact.
heron
Post by heron »
Hello, did you test it with a clean setup?
I mean by deleting user.cfg to get a reseted preferences and parameters.
FBXL5
Post by FBXL5 »
heron wrote: Wed Apr 19, 2023 12:34 pm Hello, did you test it with a clean setup?
Yes, with a fresh .cfg file I found out that it depends on the Transparent objects setting back in August.
heron
Post by heron »
FBXL5 wrote: Wed Apr 19, 2023 1:25 pm setting back in August.
Ops, I missed the other page of the thread, sorry for the noise.
