[Sketcher] Arrow heads disappear on hiding the grid
FBXL5
Post by FBXL5 »
I observed a strange behaviour: :shock:
When I toggle the sketcher grid off, some arrow heads disappear:
It looks rather like a bug than a feature. 8-)
Is this a known issue?
VanishingArrowHeads.FCStd
(69.52 KiB) Downloaded 82 times
OS: macOS 10.15
Version: 0.21.29997 (Git)
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Locale: C/Default (C)
  * Reinforcement
  * Render 2022.2.0
  * sheetmetal 0.2.56
  * Help 1.0.3
  * Curves 0.5.4
  * Assembly3 0.11.3
Shalmeneser
Re: [Sketcher] Arrow heads disappear on hiding the grid
Post by Shalmeneser »
I've encounter this bug before.
* Don't know where it comes from
* Don't know how it has autorepaired
No problem here. Did you reset the config?
OS: macOS 10.16
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.3.51
  * sheetmetal 0.2.56
  * ExplodedAssembly
  * Curves 0.5.4
jnxd
Post by jnxd »
Shalmeneser wrote: Wed Aug 10, 2022 11:17 am I've encounter this bug before.
Could you at least post your about info? Could give some clues of what's happening. It doesn't have to be able to reproduce the bug right now, but it will help if it's close enough to a version that does.
Shalmeneser
Too many versions. :lol:
I can reproduce too
OS: Linux 5.18.16-arch1-1 (KDE/plasma)
Version: 0.21.29967 (Git)
Build type: None
Hash: 43dcbe4a315171b62642a95a0e54ba1c394edab5
Python 3.10.5, Qt 5.15.5, Coin 4.0.1, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C) [ OS: English/United Kingdom (en_GB) ]
  * fasteners 0.3.50
  * Assembly3 0.11.3
  * CfdOF 1.17.7
  * Plot 2022.4.17
  * Curves 0.5.4
  * DynamicData 2.46.0
  * Dracula 0.0.2
  * SelectorToolbar
  * FC_SU
  * A2plus 0.4.56a
  * AirPlaneDesign
  * Glass
  * Assembly4 0.12.3
  * CurvedShapes 1.0.4
  * CubeMenu
  * sheetmetal 0.2.56
FBXL5
Post by FBXL5 »
Found it! :D
A property in the preferences hides the arrow heads.
Preferences - Display - 3D Viev - Transparent objects:
- One pass: Arrow heads all visible
- Bacface pass: Hides arrow heads.
Can you confirm?
FBXL5 wrote: Thu Aug 11, 2022 8:58 am Can you confirm?
Confirmed.
How did you find it? I ask because I currently have issues with my config as well.
And by the way: what does this setting do?
FBXL5
Post by FBXL5 »
chrisb wrote: Thu Aug 11, 2022 12:12 am Did you reset the config?
Yes, I renamed user.cfg and FreeCAD created a new one.
All arrow heads were visible, with or without grid enabled.
chrisb wrote: Thu Aug 11, 2022 9:52 am How did you find it?
I started editing the preferences with sketcher open and grid disabled.
When I hit apply after switchng from One pass to Backface pass i noticed that the arrow heads were invisible again.
Then I reaktivated my old user.cfg and I was able toggle the arrow heads with the same property as well.
chrisb wrote: Thu Aug 11, 2022 9:52 am And by the way: what does this setting do?
I have no clue now, but I may had one when I switched to Backface pass some time ago. :)
I'll have a look what the wiki has to offer about this property.
Edit:
That is what the wiki knows: Preferences_Editor#3D_View
Roy_043
Post by Roy_043 »
I saw a mention of this on the Sketcher_Preferences page.
I can't reproduce this in either V0.19, V0.20 or V0.21. So this bug may be OS or hardware related.
@FBXL5 Do you still get this in more recent dev versions?
