Part Check Geometry - move dialogue buttons
heda
Post by heda »
by moving the buttons on the task dialogue 2 things are improved:
a) one does not have to scroll down to see the buttons
b) the dialogue does not have to be so wide (on my box i always have to widen the combo-view to see the run-check button)
current layout
proposed layout
Shalmeneser
Re: Part Check Geometry - move dialogue buttons
Post by Shalmeneser »
[Run check] [Close]
--Settings----------------
--Check geometry results--
-- Shape contents---------
:?: 2 buttons and 3 inside 'windows'.
I believed this has been discussed before not too long ago too. IMO the widget should have tabs for settings and results rather than buttons but I agree the buttons should be up.
kisolre
Post by kisolre »
I was going to create a FR but this came up in the search. It looks like a simple solution/fix and since a release is approaching it is better to do it now instead of a year later ;)
So just a bump and if needed I could create a FR in Open discussions or the tracker?
kisolre wrote: Sun May 07, 2023 5:00 pm I was going to create a FR but this came up in the search. It looks like a simple solution/fix and since a release is approaching it is better to do it now instead of a year later ;)
Better now IMHO, as it is very useful.
It will be out of the Part WB? so it will be available on every WB?
kisolre
Post by kisolre »
onekk wrote: Mon May 08, 2023 10:06 am It will be out of the Part WB?
I have it in a custom toolbar so not really an issue for me. But having it accessible without having to switch to PartWB would be nice.
kisolre wrote: Mon May 08, 2023 10:16 am ...
This is the point as it is udeful even when working with other WB, like PartDEsign or Curves WB (only to cite two often used).
