Performance: Subtractive helix & Polar Pattern
imm
Re: Performance: Subtractive helix & Polar Pattern
Post by imm »
chrisb wrote: Wed Mar 08, 2023 10:14 am I have reworked the file to use only a single pipe and no PartDesign helix.
What did you use to produce the 'Helix' object ? I am not aware of an alternate means to create the helix..Can you tell me the workbench it is available on? or is it a macro?
Jolbas
Post by Jolbas »
imm wrote: Thu Mar 09, 2023 7:42 am What did you use to produce the 'Helix' object ? I am not aware of an alternate means to create the helix..Can you tell me the workbench it is available on? or is it a macro?
It's in the PartDesign workbench as in the quote in your own post. Look for Additive helix in the toolbar.
imm
Post by imm »
In his file the icon for the helix is not the 'additive helix' symbol.
Jolbas wrote: Thu Mar 09, 2023 8:05 am It's in the PartDesign workbench
No. It is Part Helix, which I added to the body. Alternatively you can use the helix as a BaseFeature or create a PartDesign ShapeBinder for it.
imm
Post by imm »
I took the time to recompute these files from FreeCAD 0.21 and FreeCADLink 2023.131 on my system ( ttr is 'Time To Recompute')
    FREECAD VERSION                   fc0.21.0      rtfc2023.131
 a19tooth-LH20deg-Involute-Spline_cb  4:07 ttr         1:23 ttr
 a19tooth-LH20deg-Involute-Spline     5:22 ttr         2:30 ttr
I have confirmed that neither of these Builds have the Software OpenGL enabled in Preferences.
At least on the Windows Builds from my view using taskviewer the RealThunder build is using all of the CPU cores at some point.
That seems to be were the bottleneck is in FreeCAD 0.21.
My FreeCAD 0.21 details are here.
# fc0.21.0 details
# system
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.8.16, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * AnimationFreeCAD 1.0.0
  * Curves 0.6.5
  * freecad.gears 1.0.0
  * Nodes 0.1.36
  * PieMenu
  * sheetmetal
# libraries
Boost 1_74
https://www.boost.org
Coin3D 4.0.0
https://coin3d.github.io
Eigen 3.4.0
https://eigen.tuxfamily.org
FreeType 2.12.1
https://freetype.org
KDL
https://www.orocos.org/kdl
libarea
https://github.com/danielfalck/libarea
Open CASCADE Technology 7.6.3
https://www.opencascade.com/open-cascade-technology/
Point Cloud Library 1.12.1
https://www.pointclouds.org
PyCXX 7.1.7
http://cxx.sourceforge.net
Python 3.8.16
https://www.python.org
Qt for Python (PySide) 5.15.8
https://wiki.qt.io/Qt_for_Python
Qt 5.15.6
https://www.qt.io
Salome SMESH 9.8.0.2
https://salome-platform.org
Qt for Python (Shiboken) 5.15.8
vtk 9.1.0
https://www.vtk.org
Xerces-C 3.2.4
https://xerces.apache.org/xerces-c
Zipios++
http://zipios.sourceforge.net
zlib 1.2.13
https://zlib.net
And my FreeCADLink details are here
# rtfc2023.131 details
# system
Version: 2023.131.26244 +5365 (Git)
Branch: LinkDaily
Hash: 73c4ca254c5de8849d104973482e98399fb24863
Python version: 3.10.8
Qt version: 5.15.4
Coin version: 4.0.1
OCC version: 7.6.3
# libraries
Boost 1_74
http://www.boost.org
Coin3D 4.0.1
Eigen3 3.4.0
http://eigen.tuxfamily.org
FreeType 2.12.1
http://freetype.org
KDL
http://www.orocos.org/kdl
libarea
http://www.opencascade.com
http://www.pointclouds.org
PyCXX 6.2.8
Python 3.10.8
http://www.python.org
PySide 5.15.5
http://www.pyside.org
Qt 5.15.4
http://www.qt.io
Salome SMESH
http://salome-platform.org
Shiboken 5.15.5
vtk 9.1.0
https://www.vtk.org
Xerces-C 3.2.4
Zipios++
zlib 1.2.13
http://zlib.net
user1234
Post by user1234 »
imm wrote: Wed Mar 08, 2023 9:09 am OK File can be downloaded from https://github.com/webmite/FreeCAD-Samples
Is that Body a tool for a cut (for example for a pinion)?
Greetings
user1234
imm
Post by imm »
It is derived from my work on
viewtopic.php?p=653410&hilit=involute+spline#p653410
Intent is to produce an external additive spline on a base that can be linked as an external file at the end of the drafting process.
It can be linked to and used to do a boolean cut of any existing gear blank or shaft.
I am recording the toothcount and angle in the filename and standardizing the length, so people can import, align with the shaft, do a transform along the shaft to lengthen or shorten the 'cut' and have the helical splined gear 'feature' done with minimal interaction with the other shaft features.
