Info: project commented under LinkBranch.
jpg87
Post by jpg87 »
Following the article https://forum.freecad.org/viewtopic.php ... 83a8c09407
I decided to make a series of documents to show workflows to reinforce the toponaming problem already well advanced in LinkBranch by @realthunder .
Here are the pieces I drew and I am writing the comments and illustrations :
Edit : Sorry, I forgot to put the links!
http://help-freecad-jpg87.fr/05_excomment_ind.php
http://help-freecad-jpg87.fr/00fr/05_excomment_ind.php
jpg87
Re: Info: project commented under LinkBranch.
Post by jpg87 »
Videos of left and right crankcases are available :
http://help-freecad-jpg87.fr/0501a_excomment_ind.php
http://help-freecad-jpg87.fr/0501b_excomment_ind.php
and in french
http://help-freecad-jpg87.fr/00fr/0501a ... nt_ind.php
http://help-freecad-jpg87.fr/00fr/0501b ... nt_ind.php
You will find in these examples :
  • uses of master sketches independent of part bodies with import of geometries,
  • carbon copies of some of these sketches (requiring to use the key combination Ctrl + Alt in addition),
  • the use of Sub-object face binder to transfer common geometries from one part to another,
  • imports of directly extrudable geometries ...
numanair
Post by numanair »
Good stuff. Thanks!
With step "Form of revolution around the motor shaft" and "Ribs of the central fabric of the casing on the motor shaft side", why not use the same reference plane for revolving as drawing the rib? I have not been following this model closely, so I am not sure which sketches were created first, but it seems that it would be more parametric this way (as it removes the 50mm plane offset).
Edit: your French links in the last post are broken.
jpg87
Post by jpg87 »
numanair wrote: Mon Aug 01, 2022 7:38 pm Good stuff. Thanks!
Thanks, it's always fun!
numanair wrote: Mon Aug 01, 2022 7:38 pm With step "Form of revolution around the motor shaft" and "Ribs of the central fabric of the casing on the motor shaft side", why not use the same reference plane for revolving as drawing the rib? I have not been following this model closely, so I am not sure which sketches were created first, but it seems that it would be more parametric this way (as it removes the 50mm plane offset).
Perfectly accurate! This is because I used images from the technical documents I had. I didn't ask myself any more questions...
numanair wrote: Mon Aug 01, 2022 7:38 pm Edit: your French links in the last post are broken.
Thanks for pointing it out, it's fixed: I had absentmindedly copied the links from my local tests.
jpg87
Post by jpg87 »
Always for information, I added comments of construction for :
https://help-freecad-jpg87.fr/0501f_excomment_ind.php
https://help-freecad-jpg87.fr/00fr/0501 ... nt_ind.php
... and for fillet resolution
https://help-freecad-jpg87.fr/0501g_excomment_ind.php
jpg87
Post by jpg87 »
