thomas-neemann
Posts: 11958 Joined: Wed Jan 22, 2020 6:03 pm
Post
by thomas-neemann » Thu Jul 14, 2022 8:51 am
if i export this file
as ifc i get that.
1045.ifc
(29.54 KiB) Downloaded 61 times
where is the mistake?
Version: 0.20.29177 (Git) AppImage
* Curves 0.5.1
thomas-neemann on Sat Jul 16, 2022 7:29 pm, edited 1 time in total.
yorik
Posts: 13665 Joined: Tue Feb 17, 2009 9:16 pm
Post
by yorik » Thu Jul 14, 2022 10:38 am
Need to have a better look at it, but one thing you could do inbetween, is to open the ifc file in another app. so we know if the problem is in the IFC file or not, so we know if the problem is caused by import or export operation
thomas-neemann
Post
by thomas-neemann » Thu Jul 14, 2022 10:48 am
yorik wrote: ↑ Thu Jul 14, 2022 10:38 am
thanks for the effort, it seems to happen with the export. ifcplusplus also shows it that way
edit
also here
thomas-neemann on Thu Jul 14, 2022 3:52 pm, edited 1 time in total.
user1234
Posts: 3512 Joined: Mon Jul 11, 2016 5:08 pm
Post
by user1234 » Thu Jul 14, 2022 1:19 pm
I think there is translation error, i think you mean troubleshooting.
Greetings
user1234
thomas-neemann
Post
by thomas-neemann » Thu Jul 14, 2022 1:38 pm
my english is bad, i use a translator. the cross-check brought the desired result
user1234
Post
by user1234 » Thu Jul 14, 2022 2:15 pm
Yes, this is wrong translated, in that case effort is the correct word. The translator translated Mühe, wie die schweren Mühen (Probleme).
Greetings
user1234
thomas-neemann
Post
by thomas-neemann » Thu Jul 14, 2022 3:52 pm
user1234 wrote: ↑ Thu Jul 14, 2022 2:15 pm
Thanks for the tip, I changed it
thomas-neemann
Post
by thomas-neemann » Sat Jul 16, 2022 7:29 pm
workaround: before exporting, mark everything, create a simple copy in part. export the simple copy as ifc
yorik
Post
by yorik » Sun Jul 17, 2022 1:44 pm
I would say the culprit is one of the mirror objects. (IFC doesn't support mirroring anyway...}
I would try mirroring the 2D profiles first. then extrude all 4. That should translate well to IFC
thomas-neemann
Post
by thomas-neemann » Sun Jul 17, 2022 3:56 pm
yorik wrote: ↑ Sun Jul 17, 2022 1:44 pm
thanks for the support, it works wonderfully, even the holes are round
