PCB thermal analysis revisited
Moderator: bernd
gerhard63
Re: PCB thermal analysis revisited
Post by gerhard63 »
In the last days I started to dig into the FreeCAD world of thermal simulation of pcbs.
After a lot of tries to get a kicad pcb into freecad with KiCadStepUp, I found this thread and fcad_pcb from @realthunder.
Unfortunetally Im not able to start the scripts. It stopps running with the the following error message:
2023-01-07 16_29_39-FreeCAD 0.20.1.png (15.73 KiB) Viewed 1306 times
Does any one know about this problem?
I spent nearly the whole day without any success...
Thanks in advance.
OS: Windows 11
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * Help 1.0.3
  * kicadStepUpMod 10.16.8
  * sheetmetal 0.2.60
easyw-fc
Post by easyw-fc »
gerhard63 wrote: Sat Jan 07, 2023 3:35 pm In the last days I started to dig into the FreeCAD world of thermal simulation of pcbs.
Thanks in advance.
OS: Windows 11
  * Help 1.0.3
  * sheetmetal 0.2.60
I have no issue with
OS: Windows 10 Version 1909
Version: 0.20.2.29603 (Git)
from your errors it seems you have an outdated fcad_pcb release version
gerhard63
Post by gerhard63 »
I used the version from Feb 18th, 2020 downloaded here:
https://github.com/realthunder/fcad_pcb ... es/tag/1.1
Where can I find the latest?
easyw-fc
Post by easyw-fc »
gerhard63 wrote: Mon Jan 09, 2023 10:58 am I used the version from Feb 18th, 2020 downloaded here:
That is 3 years old...
you have to download directly from GH
Please follow instructions on readme
https://github.com/realthunder/fcad_pcb#readme
https://github.com/realthunder/fcad_pcb#installation
gerhard63
Post by gerhard63 »
With windows I cannot use git and clone.
I download all files and put it unchanged into the macro directory, correct?
easyw-fc
Post by easyw-fc »
https://gitforwindows.org
or
https://git-scm.com/downloads
then git clone it in the downloading directory and follow the readme commands
gerhard63
Post by gerhard63 »
Hi easyw-fcw
The phyton script is running now correctly. But with max. 2 layers. Multilayer seems not tobe supported.
However...
Thanks for your help.
easyw-fc
Post by easyw-fc »
gerhard63 wrote: Mon Jan 09, 2023 5:12 pm Hi easyw-fcw
However...
Multi layers are supported..
https://github.com/realthunder/fcad_pcb ... ry-instead
